Bilge pump float switch
Old 07-02-2014, 02:33 AM   #1
norri is currently offline
My Model: Z212 Limited Edition
My Engine: 5.7 Alpha One
Send norri:
Default Bilge pump float switch
Hi, I have a 1999 Shabah Z212 and I noticed that the bilge pump doesnt run when float switch is raised up, I metered the atwood float sw and it measures 106 ohms when raised. Does any one have an idea.
  • Old 07-02-2014, 03:02 AM   #2
    Default Re: Bilge pump float switch
    You could take it apart and clean it along with cleaning the connections but its likely just easier to replace it.
    Old 07-02-2014, 11:15 AM   #3
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Agree with mikey. West marine or overtones has them all day long and they're cheap.
    Old 07-03-2014, 01:47 AM   #4
    Send norri:
    TY for the input, I wasnt sure it was bad with 106 Ohms resistance, the pump runs fine if I turn on the bilge switch., just doesnt run when float sw is activated. my restance reading were right on the 2 wires coming off the switch.
    Old 07-03-2014, 03:15 AM   #5
    So just buy a new float switch....
    Old 07-04-2014, 02:55 AM   #6
    Send norri:
    will do TY and I'll let u know what happens.
    Norri
    Old 07-08-2014, 01:27 AM   #7
    Send norri:
    Today I replaced the float switch, still doesnt work, my guess is it never worked and the original owner never knew it. I should have 12v at the sw all the time and I never do, so it has to be the wiring, does anyone know where the 12v comes from.
    Old 07-08-2014, 01:46 AM   #8
    Your wiring at the bilge pump should be a brown wire, a brown/white wire and a ground wire. The ground is likely at the block on the transom beside the engine. The fuse for the bilge should be a 5 amp one, top row, 4th from the left side up underneath the drivers console. Pull each of the connections at the pump & clean/reconnect them, then i would say to check the ground block on the transom next.
    Old 07-08-2014, 02:03 AM   #9
    Did you even check the fuse?
    Old 07-08-2014, 02:05 AM   #10
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    You should also have a constant power from the battery independent of the ignition circuit
    Check the fuse in that wire. Also check k to see if you are missing the positive or negative. For example. Test leads don Bart positive at the batter and the negative lead at the pump. And positive lead at the float switch and neg at the battery. That would you if you have a prob in the ground side.or the positive side.
    Bilge Pump barry johnston Original Mariah Talk 4 04-16-2013 01:55 AM
    Bilge pump alliedasset Boating 101 2 05-30-2012 02:36 AM
    Bilge pump andyc Sea Fox - Mariah Talk 7 07-14-2009 04:01 PM
    bilge pump John Miller Original Mariah Talk 7 05-18-2009 07:25 PM
    There are 283 users
