Few questions for winter projects...
Old 01-31-2014, 03:39 AM   #11
gahooligan's Avatar
My Model: 202
My Engine: 5.7l
Send gahooligan:
Default Re: Few questions for winter projects...
Another member sent me some suggestions on colors. I don't have a Miami store in atl so I need to call them for some samples.
  • Old 02-08-2014, 03:27 PM   #12
    Mariah350's Avatar
    Mariah350 is currently offline
    Send Mariah350:
    As far as the carb, your current carb is a Weber/Carter style. Replace your current carb with a Edelbrock Marine 600CFM part # 1408 Performer Series with electronic choke which is of the same design as the stock Weber on your Mariah. All throttle and fuel lines are direct connections without any alterations. You will eliminate the "open throttle" hard to starts. Should run without tuning right out of the box. Your current carb is probably dumping to much fuel at idle and you probably have a lot of soot on the transom especially if you run through hull exhaust.
    1995 Mariah Shabah 212 Z
    Performance Built 355 Vortec
    Alpha One Merc Laser II 21''
    GPS 64 Mph @ 5100 RPM
    Old 02-09-2014, 11:32 AM   #13
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    It's that edlebrock a two barrel? That's what I have on there now.
    Winter Motorcyclesmack Chit Chat/Off-Topic 9 12-04-2012 07:34 PM
    SOME of my projects for the off season ConVICK_Pitbull Projects 2 10-12-2012 08:05 PM
    A few end of season projects theeasynine Original Mariah Talk 8 06-20-2011 01:34 PM
    Pictures of some of my projects/modifications Talari240ZinAZ Projects 8 07-19-2009 01:59 PM
    How to tell winter is still here.... mikeyt Chit Chat/Off-Topic 4 04-06-2009 04:45 PM
    There are 704 users
