Hatch Motor
Closed Thread
Old 12-20-2013, 04:00 PM   #21
Mariah350's Avatar
Mariah350 is currently offline
Send Mariah350:
Default Re: Hatch Motor option Here you Go
Originally Posted by norri View Post
I need a power hatch motor, took it apart today to find the shaft was sheared at first bearing, motor has a Fasco name w a part # 2809-540-060, does anyone have a source. TY
I'm also looking for the 12v power covered receptacle thats in below radio on my 1999 Z212.
Here is the link. There are several others.
18 Inch Electric Hatch Actuator - CP Performance
1995 Mariah Shabah 212 Z
Performance Built 355 Vortec
Alpha One Merc Laser II 21''
GPS 64 Mph @ 5100 RPM
Thank you Mariah350 for this useful post!
norri (12-21-2013)
  • Old 12-21-2013, 12:25 AM   #22
    norri is currently offline
    My Model: Z212 Limited Edition
    My Engine: 5.7 Alpha One
    Send norri:
    TY for everyones help, only problem I have is how do I load my pix from my comp.
    TY
    Gary
    Old 12-21-2013, 12:30 AM   #23
    doaclnr is currently offline
    My Model: Z302
    My Engine: Volvo Penta 8.2 DP
    Send doaclnr:
    that's above my pay grade... lol
    doaclnr
    99 Z302 8.2 DP
    Old 12-21-2013, 12:36 AM   #24
    TY
    Gary
    When you enter your response to this post just scroll down the page before you hit 'Submit Reply' and you will see a button entitled "Manage Attachments". Click on that button then click on "Choose File" so that you can select what pics you want from your computer. You can attach up to 5 pics. Then hit 'Upload'.
    Old 12-21-2013, 02:25 AM   #25
    Mariah350's Avatar
    Send Mariah350:
    Default All boats have flaws
    IMO,
    All boats no matter what the manufacturer or model have design and build flaws. You just have to know what to look for.
    Just go to some boat shows and look at the corners cut and the odd designs from motor mount designs to rub rail installs.
    It is not just limited to low price boats but also the higher priced models. Over time and numerous summers, without constant care from the engine to the gel coat, all boats will look like crap.
    I have been in some high priced new boats over the years were I could hear the floor cracking under my feet.
    All boats currently are way overpriced and not worth the prices so just buy used.
    Old 12-23-2013, 01:57 AM   #26
    Send norri:
    Hi everyone, here's the pix I promised of my limited editions problem areas. 79 & 80 show where I had to enlarge cutouts to seat the switches fully on both ends, 95 is lower hull damage, 97 is damage at ladder, 91 is dr side dash inside repair w 86 showing the outside of that corner, 81-83 show dr side lower panel where switche spade lugs are against rear fg panel w rear panel blocking 12volt outlet which was broken and thrown over panel w wires still attached, 84 shows window brace after bend at glass frame and redrilling hole at lower front hole up about 3/8", 85 shows after drilling hole, 75 shows the large gap between outer panel and green hull. I tried sending only a few of the pix, want more info please contact me.
    TY
    Gary
    Old 12-23-2013, 02:14 AM   #27
    My Model: Z302
    Send doaclnr:
    That is not factory damage...
    doaclnr
    99 Z302 8.2 DP
    Old 12-23-2013, 03:20 AM   #28
    x2
    Old 12-23-2013, 03:37 AM   #29
    You know what it boils down to norri...........you bought a 14 yr old boat!!
    They all need work. It ain't a Carver , it ain't some custom hand built boat. It doesn't have a 100,000 mile warranty!
    It's a factory production boat.
    If it's such "Lemon" that you say it is , I , for one , would be more than happy to relieve you of your burden (for a less than market price , since it is so flawed).
    Fix it or sell it
    Enough said
    Old 12-28-2013, 03:01 AM   #30
    Send norri:
    Ur right Larry it is 14 yrs old and has no hours on it and has been in storage since 2003, I was just trying to point out a few of the poor construction areas, except for the hull damage all were from factory 4 sure. I have and will fix as much as I can.
    Ty
    Gar
    Closed Thread
    hatch lift motor slade watson Introductions 6 06-10-2014 03:55 AM
    Motor oil... Motoxxx43 General Maintenance 38 03-06-2013 02:00 AM
    can any one tell me what motor I have newbee1 Mercury MerCruiser 2 04-23-2012 10:59 PM
    Motor too low tonyo Original Mariah Talk 4 07-06-2011 03:06 PM
    Hatch Motor Replacement spinks99 Projects 13 05-03-2010 09:55 PM
    There are 359 users
