Question regarding 1999 Shabah 222
Old 09-24-2013, 10:37 PM   #1
Abs777 is currently offline
Send Abs777:
Default Question regarding 1999 Shabah 222
I am looking at a 1999 Shabah 222. It has a 7.4 MPI Bravo one and I cannot find any specs on this motor. Any info would be much appreciated. I went to look at this boat today and it is a beautiful boat and looks top notch as far as quality goes. Are there any things I should look out for?
Any help or info...I appreciate. Thanks Guys!
-Abs777
  • Old 09-24-2013, 11:21 PM   #2
    Default Re: Question regarding 1999 Shabah 222
    Welcome to MOC Abs!
    Can you get the serial number off of it?
    It is probably the 310 HP version.
    I'm sure some of the members with this package will chime in soon.
    Once again , Welcome
    Old 09-25-2013, 01:20 PM   #3
    Colorado Diablo's right, the 7.4L MPI is 310hp. I've had two of them, and it's a great power package. Just stay on top of the routine maintenance, filters, plugs, etc., and keep an eye on the oil level and you'll be golden until you get above the 1000 hour range. These engines start needing a little closer monitoring once you pass the 1000 hour threshold. Usually rebuilds are necessary anywhere between 1000 and 1500 hours.
    In a 222, that boat should fly with the 7.4L!
    Old 09-25-2013, 11:39 PM   #4
    Send Abs777:
    Thanks so much guys. I was really impressed with the build and quality of the boat. Definitely worth the money. Here is the VIN number US-MAB*****G899.
    Thanks again!
    -Abs
    1999 252 Shabah Gas tank question tstrenge Original Mariah Talk 3 02-04-2013 09:43 PM
    New Guy, 1999 182 Shabah KStone803 Original Mariah Talk 2 05-01-2010 03:52 PM
    1999 182 Shabah Question jerryann Original Mariah Talk 3 03-01-2009 03:06 PM
    Should I Buy 1999 202 Shabah??? george strapko Introductions 4 07-21-2008 09:00 PM
    There are 228 users
