Re: Tilt/Trim
You need to use the serial number from the drive to find the right one , it sounds like to me.
Re: Tilt/Trim
Looking at my drive serial number, 0F692395, it looks like this is the right one.
865380A13 - PUMP/MOTOR ASSEMBLY, Trim (12 Volt) $700.99 |
Re: Tilt/Trim
That is the part # I come up with too j.
I think I'd try to find a used one that has a warranty. :) |
Re: Tilt/Trim
Here you go!:wink_thumbup:
Re: Tilt/Trim
Thank you. that is awesome
Re: Tilt/Trim
Yeah , I'd snag that one in a hurry!:wink_thumbup:
I've had good luck buying from DR. |
Tilt/Trim
I just ordered it and they are over nighting it to me. What kinda fluid does it use? That way I can have everything ready once the part arrives.
Re: Tilt/Trim
Mercruiser tilt/trim fluid or 10w-30 motor oil. :)
Tilt/Trim
How much fluid? I'm gonna drain n remove as much old as I can.
Re: Tilt/Trim
Use at least 3 qts to flush the system.
Do a search , there is various ways members are doing the process. Take a look here for a little more info. |
| All times are GMT. The time now is 01:05 PM. |
