7.4 low idle problem
Old 07-07-2013, 01:16 PM   #1
frahmja is currently offline
My Engine: 7.4 Bravo III
Send frahmja:
Default 7.4 low idle problem
I have a 1995 Talari 240 with a 7.4. engine will run great on muffs and in the water for the first 15 minutes. After engine is up to temperature anytime I bring it back to idle it will load up and die. Here is what I have done so far; fuel in tank is good,, changed water separator, added in line fuel filter and last week end I rebuilt the carburetor. The carb defiantly needed cleaning & I was sure that a new kit would fix the problem. Took it to the water yesterday & ran great again for the first 15 mins. brought it back to idle and same thing loads up & dies.
Looking for help any suggestions appreciated!!!
  • Old 07-07-2013, 02:46 PM   #2
    Dozer's Avatar
    Dozer is currently offline
    My Model: Z202 shabah
    My Engine: 5.0 liter alpha 1
    Send Dozer:
    Sounds like your coil is going. It gets hot and loses voltage.
    Old 07-07-2013, 02:56 PM   #3
    Send frahmja:
    Default Re: 7.4 low idle problem
    Thanks for the reply Dozer.
    I felt the coil when the boat was having issues yesterday & it was very hot to the touch. But do you think the coil would just cause issues at idle? After it dies, I have to hold the throttle wide open & crank for 20-30 seconds before it will fire & run. Then when I put it in gear and get it over idle is runs great.
    I gone through everything on the fuel side so I guess I will start with the coil on the ignition side.
    Thanks again,
    Jeff
    Old 07-07-2013, 09:56 PM   #4
    Dozer's Avatar
    Send Dozer:
    I have a friend with a Baja and a 502 and had the same exact symptoms. We tried the carburetor as you'd assume an idle issue would be caused by that, not enough fuel. Ended up changing the coil and took care of the problems. Especially when it runs fine until it heats up.
    Old 07-07-2013, 10:35 PM   #5
    Send frahmja:
    Thanks again,
    I changed the coil & just decided to change the plugs too even though that had 25 hours on them. Plugs were black & a couple were wet too. Checked timing & it was a few degrees slow but set now. Ran it on muffs for an hour & all seems ok now. Let engine come up to temp & ran @ 1500 for 10 mins, then back to idle for 10 mins several times & did not ever load up or die. Will take it to the water this week and give it the real test.
    Appreciate the reply,
    Jeff
    Old 07-08-2013, 02:50 AM   #6
    Dozer's Avatar
    Send Dozer:
    Good deal. Pretty confident you found the problem. The low idle would load up the plugs and make the stall a certainty. Glad it seems to have worked out!
    Old 07-08-2013, 02:58 AM   #7
    PlumLazy's Avatar
    PlumLazy is currently offline
    My Model: 210
    My Engine: 5.7, Bravo III
    Send PlumLazy:
    The only other thing I can think of is the choke may not be opening all the way when it warms up.
    Bob
    Canyon Lake, TX
    '94 Shabah Z211, 5.7 Bravo III
    Old 07-08-2013, 07:03 PM   #8
    Send frahmja:
    I looked at the choke when the boat was having the idle problems & it was fully opened. When I rebuilt the carb I sell everything back to factory spec including the choke. All on the carb side appears to be OK. I have only had the boat 2 years but the coil appeared to be the original one. I hope this does it!
    Thanks for the replys.
    Jeff
    Old 07-14-2013, 07:34 PM   #9
    Send frahmja:
    The coil fixed the problem. Full day of boating yesterday & NO PROBLEMS.
    Old 07-15-2013, 01:28 AM   #10
    Dozer's Avatar
    Send Dozer:
    Good deal.
    Will not idle Luis Original Mariah Talk 7 04-24-2012 02:05 AM
    4.3L Alpha 1 Noise in Idle from Reverse? Slash9point5 Mercury MerCruiser 9 04-17-2012 04:20 PM
    boat will not idle jeffro788 Original Mariah Talk 21 06-24-2010 04:31 PM
    Mercruiser 7.4 idle issues lowerthanu Mercury MerCruiser 2 06-20-2010 03:07 PM
    Very rough idle dleeg5199 Original Mariah Talk 1 07-20-2009 02:41 PM
    There are 242 users
