power engine cover
Old 05-05-2013, 01:56 AM   #1
Rick Senn is currently offline
My Model: Mariah 240Z
Send Rick Senn:
Default power engine cover
I am having trouble with the power engine cover on my recently purchased 94 240z Talari. It starts to raise about 1/2" and then stops. It acts like it is caught or hung up on something. I don't see a fastener to undo. I can undo the rods and manually raise it, however it is heavy to support properly. Any suggestions?
  • Old 05-05-2013, 04:45 AM   #2
    Default Re: power engine cover
    First check all your connections. Bad wiring is the cause of a whole lot of these kind of problems.
    Make sure grounds are good , relays are good , and switches are working properly , and you have a full 12v going to the unit.
    That being said.......sounds like either the worm gear in the lift actuator housing is broke or damaged or the motor that runs it is weakened from age.
    You could replace with gas actuated struts. I think I saw someone used 120lb units somewhere here. I'll try and find the thread.
    Otherwise a new unit can get very spendy , very fast. Like 250-500 dollars or more.
    If you do a search on them you'll find a lot of info.
    Old 05-05-2013, 01:27 PM   #3
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Colorado is right...very expensive very fast. If you are not getting 12v at the motor, then you can try lift accelerators. Here is a link to one..
    http://www.cpperformance.com/p-13440...tor-relay.aspx
    All they do is increase the voltage to 12v so your lifts will work better. I actually took mine completely apart and polished and cleaned the coils and magnets inside and that helped mine work a little better. Plus I changed out the grease around the worm gear. They still take forever to open, but it is cheaper than replacement!
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 05-09-2013, 02:20 AM   #4
    kjdevrou is currently offline
    My Model: z202 shabah
    My Engine: 5.0L alpha one
    Send kjdevrou:
    I just fixed my lifts. they would go up but not down. the rocker switch was the problem.
    the switch was very easy to clean, it just clips apart and then I cleaned the contacts with a pencil eraser. works great now!!
    maybe check the rocker switch.
    1995 Mariah Shabah Z202 5.0l alpha one
    new engine, no power ridnwild Original Mariah Talk 19 05-26-2012 02:32 AM
    Power engine cover/hatch NogginDoc Boating 101 1 07-19-2010 07:17 PM
    Power engine hatch cover pics karmann Original Mariah Talk 0 05-09-2009 02:36 AM
    Problem w/ power engine cover joe2106 Original Mariah Talk 6 12-28-2007 04:12 PM
    Power ram for engine cover 97 Z222 Original Mariah Talk 2 11-12-2007 09:56 PM
    There are 308 users
