1999 4.3 Shabah 4V conversion
Old 12-25-2012, 09:03 PM   #1
thewanderer is currently offline
Gallery Images: 2
Send thewanderer:
Default 1999 4.3 Shabah 4V conversion
Do I have to pull the motor to get the distributor out?
  • Old 12-27-2012, 11:57 PM   #2
    Default Re: 1999 4.3 Shabah 4V conversion
    What Shabah do you have?
    I would think you would be fine not pulling it.
    Just make sure you install dizzy before putting on your 4bbl carb.
    I have plenty of room in my 18' Diablo. Hopefully one of the guys with a late 90's Shabah will chime in.
    Old 12-28-2012, 01:29 PM   #3
    Gallery Images: 2
    Send thewanderer:
    1999 Z182, it's in storage right now.
    Old 12-28-2012, 02:57 PM   #4
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    what is this 4V conversion???
    Old 12-28-2012, 11:48 PM   #5
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    4v usually means 4 barrel carb. 2v is 2 barrel carb. Im assuming he's changing his to a 4 barrel and is pulling the distributor so he can change intakes.
    Old 12-29-2012, 01:57 AM   #6
    Gallery Images: 2
    Send thewanderer:
    Correct. I am not sure there's enough room to pull the distributor or not. If not, I'm not going to bother, I'll play with props instead.
    Old 12-29-2012, 02:25 AM   #7
    I'll measure the length of my 4.3 distributor tomorrow , and give you the measurement from the hold down to the bottom of the distributor. Then all you got to do is measure from the top of your distributor up to the nearest obstruction and see if you have clearance.
    My distributor is already out due to my rebuild project.
    Old 12-29-2012, 04:44 PM   #8
    OK ,
    From the bottom of the mounting ring flange on the distributor to the end of the gear drive(bottom of distributor) is 7 3/4". If you take off the distributor cap you can gain another 1 3/4". You can probably pickup another 1/2"-1" if you take off the rotor assembly.
    So,
    If you got 6"-8" clearance above your distributor now , your good to go.
    Hope that helps you out.
    P.S.: With that conversion to the 4bbl you will pick up 15+ ponies if you'll dial it in good
    Definately noticable in the "seat of the pants" for that size boat.
    Old 12-29-2012, 07:11 PM   #9
    husker_fan's Avatar
    Send husker_fan:
    If you can pull the distributor up just a couple inches you can still pull it with the manifold. Pop the manifold up and slide it forward.
    Old 12-29-2012, 08:30 PM   #10
    That sounds great for removing it.
    How you going to install it again? Gaskets , silicone , intake , distributor. Sounds like a recipe for a intake leak to me.
    Livewell Conversion ColoradoDiablo Projects 13 06-02-2012 12:55 AM
    Engine conversion jamesalston12000 Original Mariah Talk 2 04-13-2012 05:02 AM
    Fuel / Water Separator Filter Conversion Dredd Projects 0 04-27-2010 07:30 PM
    Thru-hull conversion. doofusmarine Original Mariah Talk 1 08-01-2009 12:10 AM
    There are 276 users
