Wheel in the sky keeps on turnin'
Old 09-20-2012, 01:28 PM   #31
MW Mariah's Avatar
MW Mariah is currently offline
My Model: Shebah 180 SE
My Engine: 4.3 V6 Volovo Penta
Send MW Mariah:
Default Re: Wheel in the sky keeps on turnin'
Originally Posted by husker_fan View Post
Oh don't throw in the towel. This isn't that hard to figure out. To measure bolt pattern measure from the center of one bolt, skip one, then measure to the outside edge. You can redrill your current hubs to the correct pattern if need be too. MRW - How to measure bolt pattern
That's the way I have always known to measure a bolt pattern as well, but the place I found the hubs (etrailer.com) has the funkiest diagram showing how to measure it. Check it out, here's the hub, scroll down and look at the explanation of the bolt pattern measurement, crazy stuff.
Trailer Hub Assembly - 3500-lb Axles - 5 on 4-3/4 Dexter Trailer Hubs and Drums 845475UC1
1996 Mariah Shabah 180 SE "firefly"
4.3 Volvo Penta SX Cobra outdrive
Take me out to the black
Tell them I ain't comin' back
Burn the land and boil the sea
You can't take the sky from me.
  • Old 09-20-2012, 05:23 PM   #32
    Slash9point5's Avatar
    My Model: Barchetta 182
    Send Slash9point5:
    I had a trailer shop add a new axle and electronic breaks to my Prestige trailer. They used U-Bolts to attach the new cylindrical axle to the leaf springs. They did have to make a new longer leaf spring pivot for the back so the axle sat low enough not to rub on the fender. Both the brake set-up and then axle have worked well for 2 years now.
    Have a good one,
    Kris
    Slash9point5
    1995 Mariah Barchetta 182
    4.3L V6, Alpha I
    Old 09-21-2012, 10:22 AM   #33
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Why couldn't you keep the axle you have and just weld a mount for the brake backing plate on it?
    Old 09-21-2012, 02:57 PM   #34
    Send Slash9point5:
    The reason I needed a new axle, was with the addition of the brakes, there tire extended too far out so it rubbed on the lip of the fender.
    Slash9point5
    4.3L V6, Alpha I
    Old 09-23-2012, 07:11 PM   #35
    PlumLazy's Avatar
    PlumLazy is currently offline
    My Model: 210
    My Engine: 5.7, Bravo III
    Send PlumLazy:
    Take the hubs to a machine shop and let them redrill for the 4.75" patern, and forget the brakes. figure somewhere between $100 and $200 to do the job. (depending on their labor rates and enthusiasm for helping you make yout trailor way cool. lol). Go to a shorter 70 series tire on the 15" rim so the outside diameter is similar to the 14" 75 series so no fender rub. ... Or that's what I would do anyway. lol.
    Actually, when contemplating finding a matching spare tire rim, I just decided to put a spare tire cover over it. lol.
    And I happen to be a Ford guy, so I have a few 4.5" pattern rims around here I could switch to if I ever decided to go with something different.
    Bob
    Canyon Lake, TX
    '94 Shabah Z211, 5.7 Bravo III
    Old 09-24-2012, 04:14 PM   #36
    MW Mariah's Avatar
    Send MW Mariah:
    Hey man thanks for stopping in. The hubs linked above would be 80 for a pair and includes the bearings. I think I'd rather do that than spend 100-200 to get these re-drilled.
    I will prolly go that route, just need to get a few things done and then I will be back at upgrades and updates on the boat. (Just got her moved into her winter home (AKA my back yard on the porch under a nice steel roof. - Where I can work on her over the winter on nice days)
    So up next is winterizing - then wheels and LED lights for my trailer - then I will be working on the horn and some electrical bugs in the dash - does the list ever end?
    paddle wheel megawatt72 Original Mariah Talk 11 06-22-2012 07:42 PM
    Trailer wheel size??? ktm212 Original Mariah Talk 2 02-17-2011 08:18 PM
    Wanted: steering wheel limarian Mariah Parts For Sale & Wanted 6 08-12-2010 07:11 PM
    spare wheel? dmg5606 Trailering and Tow Vehicles 2 04-08-2009 01:55 AM
    Trailer Wheel Bearings dudders Trailering and Tow Vehicles 10 07-18-2008 09:45 PM
    There are 365 users
