Wheel in the sky keeps on turnin'
Old 09-19-2012, 10:50 PM   #21
MW Mariah's Avatar
MW Mariah is currently offline
My Model: Shebah 180 SE
My Engine: 4.3 V6 Volovo Penta
Send MW Mariah:
Default Re: Wheel in the sky keeps on turnin'
Here's the problem.
Ever seen this? Any ideas how to pull and replace the spindle?
1996 Mariah Shabah 180 SE "firefly"
4.3 Volvo Penta SX Cobra outdrive
Take me out to the black
Tell them I ain't comin' back
Burn the land and boil the sea
You can't take the sky from me.
  • Old 09-19-2012, 11:37 PM   #22
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Why do you need to replace the spindle? Can't find a hub that's the right bolt pattern I'm guessing? I'm going to have to go out and look at mine and see how its put together.....you've got me.curious now too.
    Edit....just looked at mine. The spindle is just a short stub shaft that's welded on there. If worst came to worst it'd be pretty easy to cut off and replace.
    Old 09-19-2012, 11:51 PM   #23
    husker_fan's Avatar
    Send husker_fan:
    Mine is a leaf set up. It looks identical to that picture. Rectangular tube axle, maybe a 2 x 3, piece of what looks like channel welded on the end with the stub shaft welded to the top. In that picture if its like mine the leafs bolt on right under where you see part of the u bolt there.
    Old 09-19-2012, 11:51 PM   #24
    MW Mariah's Avatar
    Send MW Mariah:
    Well I guess I will just have to forego the brakes. That was the real issue.
    Old 09-20-2012, 12:03 AM   #25
    husker_fan's Avatar
    Send husker_fan:
    What's the problem in making it work? I think I'm lost.
    Old 09-20-2012, 05:13 AM   #26
    Dozer's Avatar
    Dozer is currently offline
    My Model: Z202 shabah
    My Engine: 5.0 liter alpha 1
    Send Dozer:
    Default Wheel in the sky keeps on turnin'
    The axles are replaceable. You can get them with the flange for the backing plate at Tractor Supply for about $150. If the spindle gets worn or damaged they are throw aways. Measure the width at the spring perches and match it up. Easy replacement. Don't forget new u bolts.
    Old 09-20-2012, 12:42 PM   #27
    MW Mariah's Avatar
    Send MW Mariah:
    Ultimately, I am trying to add wheels to a trailer that were never meant to be used on a trailer. To convince both myself and the wife that it was worth it to undertake this foolhardy project I had also planned on adding electronic brakes. (If you look in my early posts I link to a company that sells electronic brake hubs with a bolt pattern of 5x4.75 - the bolt pattern required for the snowflake wheels) I have also found standard hubs that I an use, forgo the brakes and not be spending a ridiculous amount on this upgrade.
    I looked at tractor supply, they don't have "drop" axles that I found. A standard axle would have my boat sitting WAY up in the air. I did find a drop axle on trailerpartsusa.com :
    3,500 lb. Drop Axle Tube LM-360-D | 3,500 lb. Drop Axle Tube | Trailer Parts | TrailerPartsUSA.com
    It's a 3500 pound axle and it has the flanges and it's only $130 + $30 some for shipping. But I will have to go home measure a few things and then decide if I want to spend $250 just to modify the trailer enough to where I can add the these wheels. Then $125 for the wheels themselves and about 100 per tire for a grand total of almost 700 bucks just to have cool wheels.
    Old 09-20-2012, 01:04 PM   #28
    husker_fan's Avatar
    Send husker_fan:
    Is the reason you can't use the axle you have because they don't have a flange to bolt the backing plate to?
    Old 09-20-2012, 01:13 PM   #29
    MW Mariah's Avatar
    Send MW Mariah:
    Right, the hubs (that come with brakes) require a flange to bolt the brake to.
    I have found hubs that do not have brakes that are supposedly 5x4.75 bolt pattern but the diagram they show for measuring it is funky and not the same as the others I have seen. I need to check a few things before my next move.
    I have NOT thrown in the towel just yet.
    Old 09-20-2012, 01:22 PM   #30
    husker_fan's Avatar
    Send husker_fan:
    Oh don't throw in the towel. This isn't that hard to figure out. To measure bolt pattern measure from the center of one bolt, skip one, then measure to the outside edge. You can redrill your current hubs to the correct pattern if need be too. http://www.mrt-wheels.com/boltpattern.html
    paddle wheel megawatt72 Original Mariah Talk 11 06-22-2012 07:42 PM
    Trailer wheel size??? ktm212 Original Mariah Talk 2 02-17-2011 08:18 PM
    Wanted: steering wheel limarian Mariah Parts For Sale & Wanted 6 08-12-2010 07:11 PM
    spare wheel? dmg5606 Trailering and Tow Vehicles 2 04-08-2009 01:55 AM
    Trailer Wheel Bearings dudders Trailering and Tow Vehicles 10 07-18-2008 09:45 PM
    There are 366 users
