Need to pull the sending unit
Old 02-20-2008, 04:45 AM   #1
MariahShabah3.0's Avatar
MariahShabah3.0 is currently offline
Gallery Images: 1
Send MariahShabah3.0:
Default Need to pull the sending unit
Gas guage is stuck on full. Anyone have any idea of the best way to pull the sending unit on a 96 shabah 180se?
MariahShabah3.0
Monroe, NY
1996 Mariah Shabah 180 SE
  • Old 02-20-2008, 01:36 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    I've never pulled it, but on my Shabah it's easy to access. On my boat you simply flip over the back seat and there is a little panel in the floor directly in front of the engine. Flip that up and you have access to the sending unit. It's right on top of the gas tank.
    My Mariah
    Old 02-20-2008, 02:18 PM   #3
    Mine is in the same spot, same design. If i remember correctly, lift the carpet to access the panel, undo the 2 screws and you have access to the sending unit.
    Old 02-21-2008, 01:26 AM   #4
    Gallery Images: 1
    Thanks for the insight guys. It was an issue I had before winterizing. I plan on getting in there sometime in March but wanted some ideas before I started tearing up the carpet. When I lift the seat there is no visible panel. I will take a look at where the carpet ends. I will post pics if I have issues.
    MariahShabah3.0
    Monroe, NY
    Old 02-21-2008, 01:48 AM   #5
    In my case i have the 2 jump seats at the back rather than a bench style seat. The panel should be right in the middle directly in front of the engine. I have to admit i didn't know it was there until i read one of the others' post about the mfr accidentally driving the screws down thru the gas filler line!!
    Old 02-21-2008, 03:01 AM   #6
    rjobe's Avatar
    rjobe is currently offline
    Send rjobe:
    Have you isolated it to the sender unit? The reason I ask is that full equals a resistance value input to the gauge of = or > 250 ohms, so an open circuit would make your gauge read full.
    Randy
    1995 Z202 Shabah, 350 Mag / Alpha 1
    Springfield, OH (kept @ Indian Lake, OH)
    i/o lower unit gear oil bryce6horse Mercury MerCruiser 1 04-25-2008 03:53 PM
    There are 361 users
