Starter won't engage the engine.
Old 06-25-2012, 09:11 PM   #11
DFZ272 is currently offline
My Model: Z272 Barchetta
My Engine: 7.4 Bravo III
Send DFZ272:
Default Re: Starter won't engage the engine.
If the starter is good, I agree with Steve. Do you by chance have a battery disconnect switch? If you do, did you remove it also and check it for corrosion or bad connections.
Good Luck
Dan
1995 Z272 Barchetta
  • Old 06-25-2012, 10:43 PM   #12
    tobqluu is currently offline
    Send tobqluu:
    Well, i took the starter off and checked the teeth on the fly wheek AGAIN! all are there without any missing or broken. I put in another starter, replaced new external solenoid on top of the intake manifold, put everything back nice and tight, Charged the battery to full, turn the key and it does the samething.... Starter spin like crazy but nothing move on the pulley/crane shaft.
    I think its time to take it to a Marinia shop and have them take a look.
    Old 06-25-2012, 11:13 PM   #13
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    If I understand the symptoms correctly (the starter spins but does not engage the gear on the flywheel) is it a possibility that your starter is spinning in reverse. The starter gear would not kick out if the starter is spinning in reverse. This would happen if you had your battery cables reversed on the battery terminals. This is a long shot but it has happened before.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 06-26-2012, 01:54 AM   #14
    mikesnowman's Avatar
    mikesnowman is currently offline
    My Year: 97
    My Model: 272 Shabah
    My Engine: 7.4 mag
    Send mikesnowman:
    has to be the battery cables are backwards
    Starter Problems clintonbush1 Original Mariah Talk 2 07-12-2011 03:30 AM
    starter rwasson89 Original Mariah Talk 5 06-13-2011 03:51 PM
    Starter huntnfish Mercury MerCruiser 6 07-25-2010 04:41 PM
    Lower Unit will not engage All In Original Mariah Talk 5 11-04-2009 04:52 PM
    Bad starter? Dogloop Mercury MerCruiser 9 07-03-2009 09:20 PM
    There are 212 users
