Bad starter?
Old 07-03-2009, 12:05 AM   #1
Dogloop is currently offline
My Model: 1995 Mariah Talari 210 5.0 LX\V8 Alpha One
Send Dogloop:
Default Bad starter?
Boat has been setting a couple years. Charged up battery, tried to start but just get a clicking noise coming from a relay on top of the motor. Jumped the solenoid and I hear it spinning but the motor does not turn over. Bad starter? Anything I should try before removing starter? Also, is this relay thing bad too? Shouldn't it have spun the starter instead of just clicking? Thanks for any help.
  • Old 07-03-2009, 12:35 AM   #2
    markkearns's Avatar
    markkearns is currently offline
    My Model: 1994 241 Davanti
    Send markkearns:
    Default Re: Bad starter?
    I just had the same issue with mine. I would try it for several minutes...playing with the controller and then it woud just fire.
    I am not sure if its my starter or not. If so...whats it cost??
    sorry I am not much help
    Old 07-03-2009, 03:42 AM   #3
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Originally Posted by Dogloop View Post
    ... tried to start but just get a clicking noise coming from a relay on top of the motor. Jumped the solenoid and I hear it spinning but the motor does not turn over. Bad starter? Also, is this relay thing bad too? Shouldn't it have spun the starter instead of just clicking?
    Yeah, sounds like both a bad starter and a bad starter relay.
    Jim
    Old 07-03-2009, 03:47 AM   #4
    SEMIJim's Avatar
    Send SEMIJim:
    I am not sure if its my starter or not. ...
    Is it going *click*, but the starter doesn't operate? If so: Sounds like a bad starter relay.
    But you should also check your battery connections, the connections to the starter relay, and between the starter relay and starter. A poor connection in any of those can cause the symptoms you're describing.
    Jim
    Old 07-03-2009, 12:38 PM   #5
    SEMIJim's Avatar
    Send SEMIJim:
    Btw: Be careful when messing-about with the starter relay and starter. I don't know about Mariahs, but many, if not most, starting circuits have no fusing. So if something gets itself connected to ground, it could well weld itself in place and you could have a wiring and battery melt-down, perhaps a fire.
    Jim
    Old 07-03-2009, 05:35 PM   #6
    Send 300sflyer:
    Disconnect the negative terminal on the battery, before tightening any other connections. Hook it up again when you are certain everything else is tight.
    Old 07-03-2009, 07:47 PM   #7
    Send Dogloop:
    Thanks for the information and tips. I will pull the starter off it tonight and see which one it is exactly. I believe I can get a new one online for around 170.00, but there is an alternator and starter repair shop here that can rebuild it for $45.00. What do you guys think?
    Old 07-03-2009, 08:27 PM   #8
    Send 300sflyer:
    After you pull it off, check to see if there is any corrosion on the small gear or the shaft it rides on. A few years of just sitting around could be the problem...
    Is so, give it a few squirts of oil and see if you can't free it up. If you have a set of booster cables, see if you cant get it working off of a spare battery. You never know...
    If that doesnt work, then the rebuild shop sounds like a good option, provided you don't have to wait 3 or 4 weeks. Summer is too short.
    Old 07-03-2009, 09:11 PM   #9
    Send Dogloop:
    That"s what I was thinking too about it may just be "stuck" from sitting. The repair shop can have it done the same day (Monday) so the down time is much less. I will probably have them rebuild it either way just to make sure all is good. $45.00 is a cheap insurance policy to make sure we don't get stuck on the lake.
    Old 07-03-2009, 09:20 PM   #10
    Send 300sflyer:
    Sounds like a good plan.
    Mercruiser 4.3 starter azboatman Mercury MerCruiser 4 04-09-2009 03:04 AM
    Starter motor SX18 Vilanova Mercury MerCruiser 3 02-01-2009 08:11 PM
    Help with starter issues MariahShabah3.0 Original Mariah Talk 10 09-10-2007 06:04 PM
    There are 257 users
