Blown Engine
Old 06-12-2012, 01:15 AM   #1
lakeozarks is currently offline
My Model: 240 Talari
My Engine: 5.7L Bravo III
Send lakeozarks:
Unhappy Blown Engine
Was at the Lake of the Ozarks this weekend for my extended family vacation. It was about the 12th time I had my new to me 94 240 Talari out and guess what, one cylinder went down.
The mechanic gave me two options
1) A used 350 Merc w/ fuel injection ---no warranty
2) Rebuild the existing 350 Merc (carb) and get a one year warranty
I spent all the money I had on the boat and coming up with 5K will be an issue.
Any thoughts
  • Old 06-12-2012, 02:46 PM   #2
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Default Re: Blown Engine
    Did it drop a valve and smash a piston, blow a head gasket, or break a rod?
    Dan
    1995 Z272 Barchetta
    Old 06-12-2012, 05:12 PM   #3
    Send lakeozarks:
    It smashed a piston. The engine appeared to be running good as I thought it was the cone clutches that went bad. It started fine and ran good up to 25 mph then it fell flat on its face.
    I was hoping that it was only a throttle cable issue. Wishful thinking. I had prepared myself for a $1600 repair but the grim reaper showed up.
    I am still wondering is the previous owner knew about the problem. I hope not but I have to wonder.
    Rick
    Old 06-12-2012, 06:27 PM   #4
    Send DFZ272:
    I hate to hear that. Did the previous owner know? Probably not. This is a problem that seldom gives advance notice. But..if an engine is not run on a regular basis valves springs can get weak from being compressed in one position for long periods. As for rebuild or used motor with fuel injection. My humble opinion is to stick with a carb regardless of a rebuild or replacement engine. I like to keep systems as simple as possible.
    Good Luck
    Dan
    1995 Z272 Barchetta
    Old 06-12-2012, 06:43 PM   #5
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    How mechanically inclined are you? If it blew one piston, it may not have scratched the cylinder walls and a re-build would be pretty easy (if you know engines). How about mechanic friends? The hardest part of this process would be pulling the engine out and putting it back in. If you have a friend who knows engines, you can easily rebuild that engine for less than $1000, and maybe even soup it up a bit. Could be a good learning experience for you because $5K is way overpriced in my opinion unless you are getting a brand new engine.
    Good luck with it! I hope soimething good works out for you.
    DFZ272 likes this.
    Old 06-12-2012, 08:44 PM   #6
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Agreed. Even pulling the engine is not a big job. Had my 5.7 out in about an hour by myself. The biggest issue is finding a lift tall enough to pick the engine up over the sides of the boat. I used a BIG tree limb, and a come-along.
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 06-12-2012, 08:56 PM   #7
    mark43 is currently offline
    My Model: Z210 Shabah
    Send mark43:
    Sorry to hear about your engine....Check out this link...This may be a viable option for you...
    Mercruiser Engines
    Brewfixer likes this.
    Old 06-12-2012, 11:21 PM   #8
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    I agree with GregT, $5K is overpriced but I assume labor is included. I know this is way disconnected but I just put a brand new crated GM engine in my Surburban for $4k installed by a shop including all new sensors, wiring harness and radiator.
    If the Craigslist listing Mark43 supplied is legit, that is a sweet deal.
    2001 Mariah Shabah Z222
    Old 06-12-2012, 11:42 PM   #9
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    Sorry to hear about your misfortune. I feel with you as I blow a head gasket and scored a cylinder a few weeks ago. Boat is in the shop right now getting a long block out in. My quote was for 4,200 installed. I asked them to be sure to check ujoints, gimble bearing, bellows etc while they were at it. If any of these need attention it will be extra. Pricing here in Manitoba is ridiculous but what can you do? I am very quickly learning what B-O-A-T stands for.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 06-13-2012, 02:02 AM   #10
    DougR is currently offline
    My Year: 2003
    My Model: SX 20
    My Engine: 5.7
    Send DougR:
    Sorry to hear that!!!!
    I agree 5K does seem to be a little high.
    I managed to put in a new crate motor for 2,400. However, I did all of the labor myself and the marina put in my motor for free (long story)....
    -Doug
    1999 merc 3.0l blown head gasket silver04roush Mercury MerCruiser 5 08-22-2010 05:12 PM
    Blown Upper Unit MAJIC Original Mariah Talk 4 10-19-2009 03:57 PM
    There are 328 users
