Project Sunday...
Old 05-21-2012, 02:26 AM   #1
Brewfixer's Avatar
My Model: Z222
My Engine: 5.7
Send Brewfixer:
Default Project Sunday...
Well today instead of taking her out I decided to dress her up for the upcoming Memorial Day weekend. So I started with LED's. I had previously installed some LED lights here and there but as my wife said today "I have gone loco".
So I toyed with the console gauge lights and I decided to go Red. I had a few red LED lights laying around so I tried them in several gauges and what a difference.
On the fuel gauge I had a bright white LED and I thought it would be too bright at night. The speedometer has a regular incandecent red bulb I found at a local autoparts store but did not have the brightness of the LED on the Trim and Clock gauge. The other gauges still had the standard white incandecent bulbs.
While I was at it I finished my stereo console (almost) and cup holders. All the cup holders (x6) are lit up inside and out with blue LED's on a dedicated switch. They also have a Lexan ring under each one that is also lit by LED lights. I also finished (previous project) installing LEDs in all my speakers (except subs cause I ran out of LED's) and are switched together with the cup holders.
My stereo console is made of 1/4" Lexan painted black on the mounted side (back). Originally had 2 switches mounted but I expanded to 4 switches for the underwater LED lights in 2 weeks. I also installed a waterproof USB connector console mounted (can remember where I put it so it is not mounted in pic) that plugs into my stereo. Still to finish this console will be a 12vdc outlet, and the edge of the console as well as around the stereo will be backlit with LED's.
Next I also installed 2 waterproof stereo remote units one on the transom and one in the front by the anchor locker. These are self lit and they are wired to my dimmer as well.
Finally I had enough time to install a new skeg guard and rebuild my speedometer paddle wheel assembly. Whew!
Miller Time!!!
Dredd, Zackattack and TexasZ212 like this.
2001 Mariah Shabah Z222
  • Old 05-21-2012, 12:51 PM   #2
    TexasZ212's Avatar
    TexasZ212 is currently offline
    My Engine: 5.7 Mercruiser Alpha 1
    Send TexasZ212:
    Default Re: Project Sunday...
    Simply AWESOME!!!
    James
    1999 Z212 Shabah
    5.7 V8 Alpha 1 Gen ll
    Old 05-21-2012, 03:13 PM   #3
    nglauer's Avatar
    nglauer is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha one
    Send nglauer:
    That looks awesome!!! I have thought about upgrading the lights in my boat as well.. I have two lights that I plan on mounting sometime on the insides of the hull. They are LED strips that were made for running boards/nerf bars. They switch from amber to white. I thought I would mount them in the sides of the boat.. and I bought a few LED lights that I plan on adding inside the storage compartments and in front of the bow. I love the cup holders that light up as well. I may consider some of those if I find a good deal on them.
    Old 05-21-2012, 06:41 PM   #4
    theeasynine's Avatar
    My Model: z240 Talari
    Send theeasynine:
    Man very sharp! The cup holder LEDs are a nice touch.
    Patrick
    Old 05-22-2012, 02:54 AM   #5
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    The cup holders were the cheapest of all. Each led runs about $1.99 at SuperbrightLEDs.com (LD1 series). I also used these in each speaker. I just ordered another 20. You can always find somewhere to put these and are tiny (8x8 mm) with adhesive backing. The tricky part was making the Lexan (plexiglass) rings. Lots of hand shaping to get them to fit.
    Kitto likes this.
    Old 05-25-2012, 01:38 AM   #6
    Mariahvirgin's Avatar
    Mariahvirgin is currently offline
    My Model: 1996 Mariah Shabah 190 4.3L Merc
    Send Mariahvirgin:
    Very nice !!
    What did you use to fill in around your kenwood stereo? Black plexi?
    Old 05-25-2012, 04:19 AM   #7
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    Clear 1/4" Lexan (plexiglass). I spray painted the back gloss black so you get a deep shiny effect.
    Old 05-25-2012, 10:56 PM   #8
    Send Mariahvirgin:
    Thanks !!.... I'm going to try that out.
    Have to look into the LED lighting ... looks awesome !!
    Old 06-27-2012, 04:08 AM   #9
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    Finally finished installing my underwater lights... Whew! Not for the weak at heart. Drilling more holes in my boat sucks but the after-effect is awesome. She leave a beautiful wake of green or blue or both.
    Here are the lights half finished
    Here are the green lights on...
    Finally, here is the one Blue light on. The other blue light I ran out of wire inside the boat and store is 15 miles away, so this weekend I will finish her up.
    Old 06-27-2012, 05:20 AM   #10
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    WOW, that is great! Nice job, no fishes will sleep near your slip!
    Zack
    1994 Z212 Shabah
    New Stereo Project Kitto Projects 6 07-13-2011 02:52 PM
    Off season project Brian Chit Chat/Off-Topic 1 12-07-2009 12:28 AM
    model project edward cossey Projects 11 05-08-2009 08:10 AM
    Boat goes to sleep Sunday 180diablo Original Mariah Talk 20 09-30-2008 11:43 PM
    Looking for the Sun on Sunday wonsnam Introductions 0 09-25-2008 05:10 AM
    There are 279 users
