Project Sunday...
Old 06-29-2012, 12:26 AM   #11
schevel's Avatar
schevel is currently offline
My Year: 2006
My Model: sx21
My Engine: 5.0L
Send schevel:
Default Re: Project Sunday...
I just checked out the LED lights at superbright, going to order 10 tomorrow. Did you use 2 per cup holder? I am also wondering how you tied all the 3' wires on each light together. Did you extend and run all the wires to one location and then feed the power from the toggle switch? Or is it as easy as twisting them all together and crimping to power supply wire? Sorry about all the questions, just think what you did looks great.
  • Old 06-29-2012, 01:34 AM   #12
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    I actually drilled a small hole on each cupholder (where the side and bottom meet) and glued the LED to that. As for the power, I ran 2 wires (hot/ground) all around the boat to a switch and wired the switch to a fuse block I installed under the dash. I then connected my fuse block hot terminal to the accesory battery via a 12vdc/30A relay so the fuse block only works when the key is in ACC or RUN position (prevents me from leaving lights by accident). My relay is also connected to the ignition switch and that is where it gets it's signal from to turn on the fuse block.
    I then just connected the LED's to the ground and hot wires than run all around the boat.
    Sounds a lot more complicated than it really is. I think I have a drawing of my LED circuit I would be more than happy to share. I will upload it as soon as I get home tonight.
    2001 Mariah Shabah Z222
    Old 06-29-2012, 01:45 AM   #13
    schevel's Avatar
    My Year: 2006
    My Model: sx21
    My Engine: 5.0L
    Send schevel:
    Thanks, I would appreciate any drawing or help. it's supposed to be 104 degrees here in south carolina this weekend, too hot for the lake. Good weekend to work on the boat in the shade.
    New Stereo Project Kitto Projects 6 07-13-2011 02:52 PM
    Off season project Brian Chit Chat/Off-Topic 1 12-07-2009 12:28 AM
    model project edward cossey Projects 11 05-08-2009 08:10 AM
    Boat goes to sleep Sunday 180diablo Original Mariah Talk 20 09-30-2008 11:43 PM
    Looking for the Sun on Sunday wonsnam Introductions 0 09-25-2008 05:10 AM
    There are 352 users
