Rebuilt my Shelby Winch
Old 05-19-2012, 04:36 AM   #1
nglauer's Avatar
nglauer is currently offline
My Model: 180 Diablo
My Engine: 3.0L Alpha one
Send nglauer:
Default Rebuilt my Shelby Winch
I wasn't sure if anyone had rebuilt their winch.. but figured I would share a picture of mine.
I replaced the pawl, spring, 3 small gears that roll against the drum, and replaced my winch strap one that includes the strap to hold it to the trailer. The picture isn't the best... but it show's you the cover I purchased from Shelby when I ordered my parts.
Tomorrow I plan on completing the installation of my Lowrance LST 3800 - I think i'm going to try mounting my in-hull transducer with some toilet bowl wax... but I will post that in another thread to get some feedback.
Last I plan on giving it a good waxing for the season.. and hopefully we'll see some water on Sunday or next weekend depending on the weather.
If you have a Shelby winch and would like to dress it up or conceal it due to slight rust.. here is the link to the cover (although they forgot to send me my decals). | Shelby Industries
They also sell all the parts for the winches as well.. | Shelby Industries
Nick
  • Old 05-19-2012, 07:59 AM   #2
    bmckinnon is currently offline
    My Model: 212 Shaba
    My Engine: 5.0L Alpha I
    Send bmckinnon:
    Default Re: Rebuilt my Shelby Winch
    Thanks this link will come in handy!
    Old 05-20-2012, 04:03 PM   #3
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    FYI I mounted my transducer in toilet bowl was last fall. I have only been out once this year but my depth gauge performed perfectly so I know the wax route works. How long is another question but I did confirm for myself that my gauge and transducer were ok.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 05-20-2012, 07:20 PM   #4
    Nice info!
    Larry
    Old 05-20-2012, 07:21 PM   #5
    Huh???
    Old 05-21-2012, 03:02 AM   #6
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Ah,no I didn't mount it in a toilet bowl, but I did use toilet bowl wax ring to mount it in the bilge
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 05-21-2012, 02:45 PM   #7
    nglauer's Avatar
    Send nglauer:
    I tested out the was ring as well. I pressed 2/3's of it into a really gross pancake.. then pressed my transducer into it and used the remaining wax around the transducer to help secure it. It must be reading accurately because I tested it out on the river and the depths all seemed right for the area I was in. It was also reading 4ft at the backside of my trailer when I was loading/unloading it.. and I know for a fact that is correct. Sure beats using epoxy.. if it holds up! plus wiring my lowrance was super easy. I did have to drill a hold for the temp sensor though.. but it turned out decent, although I hate drilling holes in my boat about as much as I hate jumping in cold water lol.
    I will try to attach a picture of the install... although the pictures didn't come out very well on my phone.
    Old 05-21-2012, 02:51 PM   #8
    nglauer's Avatar
    Send nglauer:
    My motor looks like it has corrosion in the one picture, but it's dust from where I sanded the fiberglass in the hull. I washed everything down before I took it on the river for a test run.. then washed it all back down once I got back. Hopefully we will get to take it out this coming weekend. I did notice a metal rattling noise at higher RPM when I took it out. I'm not sure what the noise is.. it's only at higher speeds and sounds like something hitting something. Almost a rattling/buzzing noise. I thought it was my spare prop hitting the hydraulic pump so I moved it and it didn't go away. I will try to remove my top on the next trip.. perhaps it is rattling back there at certain RPM's. Anyone have any suggestions? I have the 3.0L with Alpha 1.
    Nick
    Old 05-21-2012, 02:53 PM   #9
    nglauer's Avatar
    Send nglauer:
    So when you check the depth of water in the bowl.. do you do that before or after you flush? I prefer to avoid water with debris as well lol.
    Old 05-22-2012, 12:43 AM   #10
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    I did spot some fish at about 6", didn't catch any though.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Rebuilt my '99 Jubilee aaron999888 Original Mariah Talk 13 08-29-2015 02:06 PM
    Shelby Industries, customer service feedback nglauer Trailering and Tow Vehicles 0 07-24-2011 01:07 AM
    Motorized Boat Winch Douglas Alderman Chit Chat/Off-Topic 3 11-01-2009 01:28 AM
    Black exhaust after rebuilt carb was installed. abillmann Mercury MerCruiser 5 07-21-2009 01:35 PM
    There are 411 users
