1994 Talari 240...trim issue
Old 05-08-2012, 01:25 AM   #1
lakeozarks is currently offline
My Model: 240 Talari
My Engine: 5.7L Bravo III
Send lakeozarks:
Default 1994 Talari 240...trim issue
I just purchased a 1994 Talari 240 w the 5.7 Bravo 3. The boat is great however there are a few issues.
1) the trim will only raise up slightly. It will not go up to the trailer position but his is not a problem because it stays on the lift. I would like to raise it up to get it completely out of the water. anyone know of the causes for this issue
2) one time and one time only the boat went into reverse but would not go back into forward...it would go into neutral but not in forward. I shut off the engine then it worked fine. I am torn between mechanics...one says cone clutch...one says shifter cable.....the back story is that the previous owner slammed the boat into reverse at high speed to avoid a collision. this problem only happened once to previous owner and shutting off the engine solved the problem for him.
I will stick w these issues for now.
Oh yeah I love the boat....
Rick
  • Old 05-08-2012, 01:34 AM   #2
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Default Re: 1994 Talari 240...trim issue
    It should go part of the way up using the up/down button. There should be a square button further down the shifter that is for "trailer trim" At least on mine anyway. It's a 99 model.
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Thank you DCB_MINDED for this useful post!
    lakeozarks (05-08-2012)
    Old 05-08-2012, 02:10 AM   #3
    What he said.
    And i probably wouldn't worry about the shift issue unless it happens more often than once.
    propeller for my 1994 210 talari? My 210 Talari Prop Talk 2 07-06-2018 06:09 PM
    newbie - opinions on a 1994 Talari 220 pykebaot Original Mariah Talk 7 06-20-2017 02:22 AM
    Wanted: 1994 180 Talari seat . Jim Ingelbeen Mariah Parts For Sale & Wanted 1 02-05-2012 04:34 PM
    Just got a 1994 Talari z190 jnd1022 Introductions 2 08-27-2011 12:52 AM
    Wanted: 1994 Talari 210 speedo not working Funkycold69 Mariah Parts For Sale & Wanted 3 06-21-2010 05:15 PM
    There are 234 users
