newbie - opinions on a 1994 Talari 220
Old 06-29-2009, 05:51 PM   #1
pykebaot is currently offline
Send pykebaot:
Default newbie - opinions on a 1994 Talari 220
Hi all, great form you have here. I am very close to purchasing a 1994 Mariah Talari 220. It has the 5.7 merc with 350 hours on it. Looks in good shape. ANy opinions on this model, or things I should look for? Thanks for any help you may have!
  • Old 06-30-2009, 01:57 AM   #2
    kylakerat's Avatar
    kylakerat is currently offline
    My Model: Z220 Talari
    My Engine: 7.4 Bravo III
    Send kylakerat:
    Default Re: newbie - opinions on a 1994 Talari 220
    I have a 96 Z220 Talari and simply love it. It is a very well built boat that feels solid as a rock in rough water, no flexing or twisting in anything. I only have the usual issues with mine such as the cracked radio mounting plastic, cracking vinyl sunpad, and and occasional loose screw here or there.
    Mine has the 7.4 (454) engine with a Bravo III drive. While the boat is very slightly under-propped (for better holeshot) it will run about 60 with a light load and cruises nicely at 40 to 45.
    I don't know exactly how big the fuel tank is, but when gas is high, it breaks my heart to have to fill it up. When gas was near $5, I once put $200 in it to top it off, so I think it has around a 50 gallon tank. As long as you stay out of the 4 barrel, a tank seems to last forever.
    As with any boat, check the drive and engine out thoroughly as they're the parts that will give you the most headache, the Mariah part should be just fine!
    Old 06-30-2009, 01:14 PM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    The fuel tank in a '94 222 is 60 gallons.
    kylakerat has pretty much covered it. There are some interior bits that are difficult if not impossible to find, so custom will be your only route for things like seats, upholstery, and the dashboard areas. We have a sticky thread with suppliers for most of the other parts. If it's been well maintained cosmetically, and the engine/drive check out, you should have very little cause for concern.
    My Mariah
    Old 06-30-2009, 02:29 PM   #4
    abillmann is currently offline
    Send abillmann:
    I've just been through this, and if I were to do everything again, here's what I'd do:
    0. Prepare to spend some money unless you specifically know the maintenance history.
    1. Replace the impeller, have the engine oil changed, change gear lube, install new plugs, install new shift cable.
    2. Have all hoses inspected, and plan on paying for a bellows job.
    3. Have the gimbal bearing inspected and possibly replaced.
    4. Have all the drive seals inspected and possibly replaced.
    That should torch about $1500, but will make your initial experience MUCH better!
    Old 06-30-2009, 06:38 PM   #5
    jasfiveo is currently offline
    My Model: 1994 Talari 220Z 7.4L Bravo III
    Send jasfiveo:
    I have a 1994 220z Talari with 7.4L 454 Bravo III and love it. I agree with changing the impeller. Just had mine overheat. Had to replace the impeller, thermostat, exhaust shutters, and two oil changes. I also agree with the shift cable. Mine needs replaced..don't think greasing it anymore is going to help. I love my boat....just remeber you will pay to play!!!!
    Old 07-01-2009, 12:15 AM   #6
    kylakerat's Avatar
    Send kylakerat:
    Call me gutter-minded, but that give me a chuckle!
    Back to the topic. A lengthy sea-trial will give you a lot of info, so if the buyer will let you, take it for a good long spin. Turn the drive sharp while trimmed under to see if you have any gimble bearing or u-joint noise. Run it hard, then run it easy. Idle around for a bit after then engine is completely warmed up to see if the temps stay down. Start and stop the engine from time to time to ensure good starts.
    Good Luck.
    Old 06-20-2017, 12:03 AM   #7
    RollTide is currently offline
    My Engine: 7.4L Bravo lll
    Send RollTide:
    New to the club.just purchased a 1994 Talari 240 Z.With a 454.Just try to find where I can fine some information about the boat.Also maybe some accessories.
    Old 06-20-2017, 02:22 AM   #8
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Welcome to the Mariah clan! It would be best to start a new topic instead of tacking on to an old one. Some folks would recognize this title and not even read it because of the age. And it has a different boat in the title.
    Newbie looking for Talari id help Fastech Original Mariah Talk 10 09-08-2015 02:59 AM
    Need opinions-96 Mariah Talari 240 river rat Introductions 1 04-19-2009 02:05 PM
    1994 210Z Talari $9500 obo joe2106 Mariah Boats For Sale & Wanted 0 01-13-2009 11:58 PM
    Newbie to Mariah - 18' Talari any good? kielbasa Introductions 8 09-09-2008 05:09 PM
    1994 Talari Z210 Electical paulbroeder Original Mariah Talk 2 07-29-2008 09:45 AM
    There are 246 users
