HELP!!! Under dash circuit board 96 Z272
Old 04-02-2012, 11:42 PM   #1
mikelawson is currently offline
My Model: Z272 Shabah
My Engine: 502 Bravo I
Send mikelawson:
Default HELP!!! Under dash circuit board 96 Z272
I have been scouring this forum and the web for a replacement or someone to repair mine. I lost my NAV and dash lights while working under the dash and have narrowed it down to this circuit board. If anyone has access to a parts boat or know someone who can diagnose and repair printed circuit boards, please let me know. I've tried contacting rjobe as he's helped me before, but I haven't had any luck. Thanks in advance for any help.
Mike
  • Old 04-03-2012, 12:48 AM   #2
    Default Re: HELP!!! Under dash circuit board 96 Z272
    Hopefully someone else here knows a bit about them. Randy Jobe was our guru in this area but he hasn't been heard from in quite a while now...
    Old 04-03-2012, 02:29 PM   #3
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Strange problem. I am not sure what the board controls. I will look at my boat and do a little research. I will post back in a day or so
    Happy Boating
    Dan
    1995 Z272 Barchetta
    Old 04-03-2012, 02:55 PM   #4
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    I remember reading on here (I think from ShabahZ250) that if you flip the light switch up, and then back down quickly that it activated the SOS sequence on the lights. That might be what it controls... But this is only a guess. If thats the case, you should be able to wire it up without the board and at least get your lights working again.
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 04-03-2012, 07:43 PM   #5
    Send DFZ272:
    From what I could find out, the printed circuit board should not stops your nav lights from working, the board mainly controls the trip computer, outside temp, water temp display. Nav light power runs from the circuit breakers, to the a multi pin connector on the switch assembly, to the lights. The circuit board is tapped into the wire running to the nav lights, but "downstream" of the lights, meaning the board should not cause the nav lights to not work, unless the board is causing a circuit breaker to trip. The manuals section has the complete wiring harness for your boat and most others, so u may want to think about that. Like I said the circuit board is mostly for the old primitive nav system and should not directly cause your light to not work. Hope this helps
    Happy Boating
    Dan
    1995 Z272 Barchetta
    Old 05-13-2012, 08:11 PM   #6
    cp55 is currently offline
    My Model: z220
    My Engine: 5.7 mag/ alpha 1
    Send cp55:
    Im certainly no guru on this but my brother in law is and he just helped me work on mine. I have mine out right now and am working on getting the relay (big Box in the middle) for mine. The nav and stern light on my z220 run off the knob to the left of the steering wheel and mine went off when I unplugged the large pin style connector on this circuit board. Maybe you have a loose connection in this plug in or need to clean it with a brush etc and dielytric grease when done. Hope this helps.
    under dash circuit board
    Z 240 underdash Circuit Board WetWilly Original Mariah Talk 10 04-02-2012 02:58 AM
    Dash Board Switches Lance Cassidy Introductions 1 08-29-2009 09:17 AM
    Counter on dash board Jkenkel Original Mariah Talk 4 08-11-2009 01:37 PM
    Circuit board behind dash? Eddie Original Mariah Talk 0 07-15-2008 01:13 AM
    There are 256 users
