Speedometer problems! 97 Mariah 180
Old 09-19-2011, 12:37 AM   #1
97mariah180 is currently offline
My Model: 180
Send 97mariah180:
Default Speedometer problems! 97 Mariah 180
I just bought the boat and the owner says the speedo worked last summer, but for some reason now it is sitting on 20mph and won't go back to zero. With a little air pressure it will climb and with a vacuum attached it will go to zero, but it goes back to 20mph every time. I have taken the gauge out of the boat and the air line is off, but the gauge still reads high! Not sure what to do here.
BTW this is the white/gold Faria gauge...
  • Old 09-19-2011, 02:15 AM   #2
    Default Re: Speedometer problems! 97 Mariah 180
    Try cleaning out the pickup hole in the outdrive and then blow out the airline towards the outdrive.
    Old 09-19-2011, 03:42 AM   #3
    My Model: 180
    Send 97mariah180:
    Tried that already...the problem is that even with the gauge completely out of the boat it still reads incorrectly. May be a problem with the gauge.
    Old 09-19-2011, 09:42 AM   #4
    If its a Faria then it has a lifetime warranty. You can arrange to return it at Faria Marine Instruments.
    www.faria-instruments.com
    Old 09-20-2011, 10:22 PM   #5
    My Model: 180
    Send 97mariah180:
    Just sent it in to Faria! Thanks for the info!
    Speedometer on the fritz tjk Original Mariah Talk 2 07-10-2011 01:33 PM
    speedometer probpel rudy General Maintenance 2 06-15-2011 02:29 AM
    speedometer reading zero mrtransistor Mercury MerCruiser 0 06-07-2010 02:48 AM
    Speedometer - hour TomasSE Sea Fox - Mariah Talk 4 03-17-2010 04:46 PM
    boat speedometer duketter Original Mariah Talk 10 07-29-2009 06:52 AM
    There are 192 users
