Rebuild or replace engine?
Old 06-30-2011, 12:37 AM   #21
darkcalling's Avatar
My Model: Z278 Limited
My Engine: 502 Bravo III
Gallery Images: 3
Send darkcalling:
Default Re: Rebuild or replace engine?
Well if anything like cars the bbc and sbc back ends bolt up the same. But for 22 hp and 200lbs dif I would stay small block myself. Run some small block headers shave even more off.
darkcalling
Z 278 Limited
  • Old 06-30-2011, 01:37 AM   #22
    rajjneef's Avatar
    rajjneef is currently offline
    My Year: 97'
    My Model: Z242 Shabah
    My Engine: 350 efi Bravo III
    Gallery Images: 3
    Send rajjneef:
    Look at the extra expense of Labor, exhaust, etc. to mount a big block. Whats 20 HP gonna give you? 2 mph? I dunno. Who's going to do this work for you? Keep that in mind too.
    Old 06-30-2011, 01:46 AM   #23
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    I think I am agreeing with Raj and Dark here. Not alot of gain for something that won't bolt right in. Plus I won't be able to get my stock Captains' Call put back in and will have to go with a custom built exhaust system which will add even more expense. And yes, Captains' Call is mandatory!
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Carb Rebuild How to? dakotaman728 Mercury MerCruiser 3 08-08-2011 12:58 AM
    need to pull engine to replace Y ring, need help corko Introductions 1 05-09-2011 01:21 AM
    need to replace console peddlerman2001 Introductions 0 08-06-2010 09:16 PM
    rebuild 95 barchetta SCOTT Introductions 2 07-13-2009 10:44 PM
    Remove and Rebuild 4.3 Mec sirbb Mercury MerCruiser 1 04-05-2009 12:58 PM
    There are 336 users
