Alarm Wiring
Old 06-07-2011, 04:15 AM   #1
wcso909 is currently offline
My Model: Shabah
Send wcso909:
Default Alarm Wiring
Thanks to the people on the forum, I was finally able to rebuild my console, install my radio and speakers, and reinstall the wiring for the kill switch. The previous owner cut the kill switch wiring (two purple wires) and placed an alarm sensor in between to bypass it. I am now left with a alarm sensor that has a tan/blue wire on one side and purple on the other. Can someone tell me where the purple side should be connected. A friend of mine says it should be connected directly to the ignition switch. The tan and blue side is already connected as it should be. I have seen the wiring diagrams on here but still cant find what I am looking for.
  • Old 06-09-2011, 02:13 PM   #2
    Cliff_Haskins is currently offline
    Send Cliff_Haskins:
    Default Re: Alarm Wiring
    I believe, stress believe, that originally the buzzer was connected in parallel with the hot side (incoming power) that runs to the line side of the kill switch. The purple wire on the kill switch will, as your friend stated, end up at the ignition switch. Basically, the buzzer wire and ign. wire in one end of a barrel connector and the other side of the connector feeds a single wire to the kill switch.
    Old 06-09-2011, 04:04 PM   #3
    My Model: Shabah
    Send wcso909:
    Thanks Cliff. My boat wiring was a mess and wanted to be sure I got it squared away correctly.
    Alarm Shabah 198SE Original Mariah Talk 14 08-31-2010 02:38 AM
    Alarm florida22 General Maintenance 2 06-20-2010 01:05 PM
    why is my alarm going off ? Wurknman Original Mariah Talk 6 06-19-2009 08:44 PM
    Alarm? jmo Mercury MerCruiser 3 09-09-2008 02:09 AM
    alarm Mark Original Mariah Talk 10 11-26-2007 05:49 PM
    There are 304 users
