Light Bulb Replacement
Old 06-01-2011, 03:27 PM   #11
rajjneef's Avatar
rajjneef is currently offline
My Year: 97'
My Model: Z242 Shabah
My Engine: 350 efi Bravo III
Gallery Images: 3
Send rajjneef:
Default Re: Light Bulb Replacement
Let us know when you guys get these installed to make sure they fit properly.
  • Old 06-01-2011, 05:22 PM   #12
    lanierz260 is currently offline
    My Model: Z260MCC
    My Engine: 5.7L Bravo III
    Send lanierz260:
    Brewfixer did you by chance replace the transom light and if so is it the same bulb as the courtesy lights? I'm ordering these and I failed to check that fixture.
    Old 06-01-2011, 07:00 PM   #13
    Nope, the transom light bulb is completely different size than the courtesy bulbs...
    lanierz260 (06-01-2011)
    Old 06-01-2011, 07:53 PM   #14
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    I was goping to look at that this last weekend but was having too much fun. I also noticed how easy it was to access the instrument cluster lights and will be converting those over to LED as well.
    2001 Mariah Shabah Z222
    Old 06-01-2011, 07:59 PM   #15
    My Model: Z260MCC
    Send lanierz260:
    Well you know we're all going to ask you the bulb size/# and how easy it is to do. Something tells me my 260 will be harder to do since my head is located against the helm. I do have an access panel on that wall in the head but it's been in the 90's down here so I don't think I'll do this until the fall or in cooler temps
    Old 06-01-2011, 08:35 PM   #16
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    Well you know the intent is there but like last week, too many big boy beverages impaired my ability to make a solid plans and execute them! I got as far as the courtesy lights. Should I have a "moment of clarity" this weekend, I will report back my findings on Monday...
    Old 06-06-2011, 03:38 AM   #17
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    well the dash lights were not as easy I thought. i was only able to pull the 3 from the center gauges (RPM, Speed, Compass). The smaller gauges will require a 4 year old with tiny fingers or the removal of the gauge. The bigger gauges took the same LED lights as the courtesy lights. The transom light if it looks like the Attwood light in the picture below said to replace with a No. 90 bulb. I think SuperBright LEDs conversion is BA9s under marine bulbs.
    Old 06-06-2011, 03:42 AM   #18
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    By the way... Attwood does have a direct replacement 3 mile LED transom light if your willing to fork out $50+ for it. I'm in consideration right now.
    Old 06-06-2011, 02:40 PM   #19
    The BA9 won't work as it's a single pole. Trust me, I tried just about everything they offered trying to find something that would work. I had a hell of a time, so I just gave up and replaced it with the Attwood incandescent replacement bulb from West Marine. I think the LED transom fixture they have is pretty sweet, and thought about replacing mine, but they were quite a bit more expensive when I was looking at them!
    Old 06-07-2011, 03:37 AM   #20
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    Yup! you are correct... The BA9 will not work. Minor detail missed by me. I can't stomach $50+ to convert to LED either. I'm sure with time we may find these fixtures on Ebay. Thanks
    Navigation Light Tie-In Slash9point5 Original Mariah Talk 3 05-17-2011 12:30 AM
    98 242 Running light DRTutt Introductions 2 05-04-2010 09:12 PM
    Wanted: docking light bulb lcoen777 Mariah Parts For Sale & Wanted 14 07-09-2009 06:41 AM
    trailer light bajabob Introductions 6 01-02-2008 10:12 PM
    There are 298 users
