Navigation Light Tie-In
Old 05-06-2011, 04:28 PM   #1
Slash9point5's Avatar
My Model: Barchetta 182
Send Slash9point5:
Default Navigation Light Tie-In
Hello MOC,
I posted this question as a follow-up to another wiring question, but I think it got buried, so I hope it isn't a problem if I start a new thread.
The question I have is, what is the best way to tie a tower navigation light to the existing stern drive navigation lighting?
Any insight is greatly appreciated.
Thank you and have a great day,
Kris
  • Old 05-16-2011, 12:55 AM   #2
    mike699's Avatar
    mike699 is currently offline
    My Model: 200 Talari
    My Engine: 5.0 L Mercruiser
    Send mike699:
    Default Re: Navigation Light Tie-In
    I would probably just find the wires that run to the stern nav lights and follow them back to the switch on the dash then splice into those. The extra current draw should be fine with the OEM wiring. The tricky part will probably be getting the wires to your tower then. What kind of tower did you get?
    Old 05-16-2011, 02:33 PM   #3
    Send Slash9point5:
    Hi Mike,
    Thanks for the reply. I got the Assault Tower by aerial and over the weekend got the wires routed from the top of the tower to under the dash. Now I just need to splice into the existing wiring. My plan is similar to what you said, but I think I am going to try to use a volt meter to check and see which set of wires are for the stern light.
    As for the splice, I think I can just use a butt splice with heat shrink tubing. From what I can tell that is the best practice to prevent corrosion.
    Kris
    Old 05-17-2011, 12:30 AM   #4
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    You may to invest in liquid electrical tape and coat your connections with that first. That will garantee an air tight connection then heat shrink over it.
    2001 Mariah Shabah Z222
    Navigation lights bethk Boating 101 2 04-13-2011 09:38 PM
    power light horseandsled Introductions 2 09-13-2010 03:35 PM
    Light Switch karmann Original Mariah Talk 2 07-07-2009 06:41 AM
    GPS Navigation ShabahZ280 Boating 101 5 09-11-2007 11:41 PM
    There are 215 users
