98 242 Running light
Introductions
Old 05-04-2010, 01:48 AM   #1
DRTutt is currently offline
My Model: 242Z
My Engine: 7.4 MPI BravoIII
Send DRTutt:
Default 98 242 Running light
Does anyone have a wiring schematic. MI have an electric stern light and my runnning light are supposed to come on when it comes on and do not. My dash lights are not coming on either. Any help would be appreciated
  • Old 05-04-2010, 08:49 AM   #2
    Default Re: 98 242 Running light
    Hi DRTutt, have you checked your fuses and circuit breakers?
    As for the schematics, unfortunately, the most detailed sets are for the older models but much of this can be applied to newer models as well but for '98 specifically, I believe all we have is a wiring diagram showing the wire termination points for the various '98 models. As a contributor you have access to all that we have in the clubs library. Start by looking through the "Original Mariah Manuals and Supplements " sub-forum.
    Old 05-04-2010, 09:12 PM   #3
    ttownmatt's Avatar
    ttownmatt is currently offline
    My Model: 240 Jubilee
    My Engine: 454 brovo 3
    Send ttownmatt:
    Are youy sure you are turning the switch in the right direction? One direction should turn them on and one will not.Just a thought.
    Running very bad need help mike2828 Original Mariah Talk 1 11-19-2009 04:32 AM
    Cable running to leg Colin Logie Original Mariah Talk 2 05-06-2009 10:41 AM
    Running Amp Power??? stereoman405 Original Mariah Talk 5 05-02-2009 12:44 PM
    What prop are you running? KSP181 Prop Talk 12 11-20-2008 10:55 PM
    There are 323 users
