1995 182 Barchetta wiring
Old 05-06-2011, 09:27 PM   #1
mmoshier is currently offline
My Model: 182 Barchetta
My Engine: 4.3 MerCruiser
Send mmoshier:
Question 1995 182 Barchetta wiring
I recently bought this boat along with a lake house. I replaced the bilge pump and everything was working fine, until I had to reconnect the wiring bundle. Now the bilge pump will not turn on and neither will the blower and when I turn any of the first three switches on the panel, all three lights on the switches come on. Other electrical functions work fine and the starter works fine. Also the fuel gage needle jumps back and forth (this was happening before the other problem)
  • Old 05-07-2011, 02:38 AM   #2
    Default Re: 1995 182 Barchetta wiring
    Sounds like you got some real electrical issues there and it sounds like someone has done a little hatchet work with the wiring. We do have wiring schematics & harness diagrams available to contributing members. Clicking on the FAQ's will get you that info. I also suspect that you've got some corrosion problems & the only way to solve that is to take connections apart and clean them.
    Same thing goes for the fuel gauge. Take the connections apart at the sender unit (do it carefully because they can be fragile) then clean & reconnect. If it still bounces around one of our members posted a DIY electrical fix for the problem. You can read about that fix here.
    Old 05-09-2011, 11:32 PM   #3
    845paulg is currently offline
    My Model: Shabah Z 272
    My Engine: 7.4 L MPI Bravo III
    Gallery Images: 12
    Send 845paulg:
    Could be a ground problem. Check your grounds. There should be a ground block on the starboard side of the transom behind the battery. I had major problems with my 1996. I replaced alot of wiring.
    Old 05-10-2011, 02:22 AM   #4
    Glad to hear you got the electrical problems sorted out
    Old 05-10-2011, 12:33 PM   #5
    Send mmoshier:
    I responded privately to both of the responders, Thanks for the help. I did find that the problem was in the grounding block. Nearly every wire was loose ans some were touching. I tightened the nuts on the block and now everything works fine. Thanks again!
    bilge pump , fuel gage , wiring
    Stereo/Lighting Wiring - 1995 Barchetta 182 Slash9point5 Original Mariah Talk 3 05-05-2011 12:01 AM
    1995 272 barchetta karmann Original Mariah Talk 1 05-19-2009 06:09 AM
    1995 192 Barchetta lncoppola Introductions 1 04-15-2009 11:54 AM
    1995 Barchetta 182 peppe Original Mariah Talk 6 06-06-2008 06:13 PM
    1995 Barchetta 182 chippat Original Mariah Talk 1 10-01-2007 02:39 AM
    There are 432 users
