Fuel filter location?
Old 04-30-2011, 01:46 PM   #1
sanukc's Avatar
sanukc is currently offline
My Model: 205 Davanti
Send sanukc:
Default Fuel filter location?
Hi!
Can you guys tell me where the fuel filter is supposed to be on a 4.3 Volvo? I am confused as to the location because I cannot seem to find the filter on the engine block where the manual tells me it should be. I found one filter on it but it looks like an oil filter. I found another filter like setup but it on the inside transom wall. Hence my confusion. Attached are the pics of my engine bay. The last two are of the filter like setup on the transom wall.
Thanks a bunch guys.
Attachment 3020
Attachment 3021
Attachment 3022
Attachment 3023
Attachment 3024
Attachment 3025
  • Old 04-30-2011, 02:54 PM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: Fuel filter location?
    The picture number 5, I think is what you said is a filter looking thing. That is your pump for the hydraulic trim operation. It is possible you do not have an actual water fuel separation filter. It looks about like the size and shape of the oil filter.
    Sorry I do not know where to direct you, I just thought I would identify the trim pump. You can make sure I am correct by having someone hit the trim while you are close to see if that actuates.
    And thanks for the spark plug identification. I guess Im ok on the right plug.
    Zack
    1994 Z212 Shabah
    How to replace a fuel pump filter?? CARL SWINDLE General Maintenance 0 05-29-2010 03:03 AM
    1/4 vs 3/8 inch fuel filter bracket Jbetschart Original Mariah Talk 1 01-29-2010 05:24 PM
    adding a water separating fuel filter jeffryb Sea Fox - Mariah Talk 0 01-18-2010 07:57 PM
    Fuel Filter Replacement? MAJIC Mercury MerCruiser 0 05-01-2009 12:34 PM
    Fuel filter location on a 2000 7.4 MPI? Jeff Barnett Mercury MerCruiser 6 11-20-2007 09:15 PM
    There are 313 users
