Mariah Z212
Old 08-31-2010, 02:27 AM   #1
Fire Fighter Martin is currently offline
My Model: Shabah Z212
My Engine: 4.3 LX/V6 Alpha One
Send Fire Fighter Martin:
Default Mariah Z212
Does any one have a picture of how and where there ATWOOD TURBO 3000 FANS are installed. I have two small air duct running to my external vent .The blowers are missing.It seems to me that one fan blows fresh are in while the other blows fumes out?I also dont know where the wires are located comming from the blower toggle switch.Any help will be appriciated.
Sorry guys that was supposed to be z212 help.
  • Old 08-31-2010, 02:26 PM   #2
    Default Re: Mariah Z212
    You're kidding.....right? Hopefully you haven't been running the boat without the air blower installed? Mine has one air blower hooked up to an exhaust vent line and a separate vent line with no blower (or is it 'sucker' ) to inhale fresh air.
    Fire Fighter Martin (09-01-2010)
    Old 08-31-2010, 06:23 PM   #3
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    What year? My '99 Z212 has a blower on the port side, mounted to the transom, just behind the trim pump. It blows air out the vent above the swim platform. The starboard side has a tube that goes into the bilge, under the engine and basically brings outside air in based on the suction from the blower side.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Thank you indykoch for this useful post!
    Old 08-31-2010, 07:29 PM   #4
    I have one blower with only one hose on the port side, mounted in the same area as indykoch. I've often thought of experimenting around and adding a second blower designed as a "sucker" to bring more fresh air in.
    Old 09-01-2010, 10:52 PM   #5
    Yes i did run the boat without but so did the previous owner.I do however open the eng compartment before starting and i stay at crusing speed so it should draft enough air.However i am going to put 2 units in mine.One for bringing in fresh air and the other for sucking fumes out. While im fixing the gimbal ring on it.
    Mine is a 94 model i havent looked yet but does anyone know where the wires to connect the blower are located.boath ot my air ducts are on the port side.Any pics out there?
    Old 09-02-2010, 01:47 AM   #6
    rajjneef's Avatar
    rajjneef is currently offline
    My Year: 97'
    My Model: Z242 Shabah
    My Engine: 350 efi Bravo III
    Gallery Images: 3
    Send rajjneef:
    The MAIN times you need the blower is if you are refueling at the docks or starting if you keep your boat in a slip. If you trailer your boat you've pretty much got more airflow in there than a blower is going to do anyway. Also if your engine is totally enclosed such as in a cruiser where its covered by the floor.
    Thank you rajjneef for this useful post!
    Fire Fighter Martin (09-02-2010)
    1994 Mariah Sheba Z212 $12,500.00 tims Mariah Boats For Sale & Wanted 0 07-21-2009 02:15 PM
    94 mariah Z212 Mariahman5.7 Introductions 8 03-20-2009 10:20 PM
    2000 Mariah z212 dieselwiezil Original Mariah Talk 20 11-19-2007 05:10 PM
    2001 mariah z212 shabah dwmax Introductions 6 10-23-2007 04:40 PM
    There are 256 users
