Alarm
Old 08-28-2010, 02:43 AM   #11
Shabah 198SE's Avatar
Shabah 198SE is currently offline
My Model: Shabah 198SE
My Engine: 5.7L Alpha
Send Shabah 198SE:
Default Re: Alarm
Originally Posted by SEMIJim View Post
You mean you have the ignition switch in the "run" position, w/o the engine running, to listen to the radio? That's not a good thing to do. With some systems, you can toast your ignition by doing that.
Our radio runs with the switch in either the "run" or "acc" position--just as it is with an automobile.
Jim
SEMIJim,
Ours is basically like that too, but it is also connected to an accessory swithch.
Shabah 198SE
  • Old 08-28-2010, 01:01 PM   #12
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: Alarm
    Originally Posted by Shabah 198SE View Post
    I don't mind having the alarm, but I would like to quiet it down a bit. Maybe I can put it in a box.
    Consider how loud that alarm isn't when you're at WOT, and perhaps with the radio blasting. If that alarm goes off under those conditions, you're going to want to know it right away. Suggest that if it annoys you that much, see if you can find a replacement alarm module, compatible with the one you have, but with a start-up delay.
    Jim
    Old 08-29-2010, 01:22 AM   #13
    Send Shabah 198SE:
    Default Re: Alarm
    Jim
    SEMIJim,
    I'm starting to get used to the alarm. I'm not sure if my Siberian Husky will.
    Shabah 198SE
    Old 08-31-2010, 01:34 AM   #14
    scubydo is currently offline
    My Model: 200
    Send scubydo:
    Default Re: Alarm
    Has anyone added a time delay relay to add 15 to 30 seconds from the time the key is turned on until the alarm starts?
    I'm going to add one.
    Old 08-31-2010, 02:38 AM   #15
    SEMIJim's Avatar
    Send SEMIJim:
    Default Re: Alarm
    Wouldn't it be easier to replace the alarm unit with one that had a built-in turn-on time delay, like the on in our boat and many other Mariah's?
    Jim
    Intermittent Alarm oneilld Boating 101 9 08-29-2010 01:48 PM
    Alarm florida22 General Maintenance 2 06-20-2010 01:05 PM
    why is my alarm going off ? Wurknman Original Mariah Talk 6 06-19-2009 08:44 PM
    Alarm? jmo Mercury MerCruiser 3 09-09-2008 02:09 AM
    alarm Mark Original Mariah Talk 10 11-26-2007 05:49 PM
    There are 237 users
