boat ladder
Old 08-18-2010, 03:25 AM   #1
drpayne is currently offline
My Model: 240 Talari
My Engine: 5.7
Send drpayne:
Default boat ladder
where can i find a ladder for my 1996 talari 240
  • Old 08-19-2010, 03:22 AM   #2
    Default Re: boat ladder
    Hi drpayne and welcome to the club,
    It just so happens that I was in this same situation with our '96 Z240 Talari too.
    The ladders were made in-house and as far as I know, are no longer available, but there is an acceptable replacement that will work with a little modification. Click here and read post #4, it has a few pictures of the old and new ladder.
    All that was required for the new ladder was drilling the bolt holes a little larger to match the original bolts, having two small Stainless Steel disks welded where the frame down stops make contact with the ladder bars just like the original ladder had and adding a couple of nylon washers between the ladder and frame where they bolt together.
    Good luck,
    Old 08-21-2010, 08:43 AM   #3
    Hi drpayne, got your message....
    I purchased our replacement ladder from a local West Marine store back in '07 and unless the ladders have changed, the West Marine part number should be 10185015 / WM-L-3-12-D (3-Step Over-Platform Ladder). Since manufacturing tolerances vary and it's been three years since I purchased mine, I suggest you measure the distance between your current ladder mounts to insure this one will fit properly and don't forget to add the SS disks or the ladder could contact and dent the rub-rail when in use.
    You can also find ladders on eBay at lower prices, but you'll need to contact the sellers for the frame dimensions before buying to insure they'll fit.
    Good luck,
    Old 08-21-2010, 06:26 PM   #4
    simpleaz's Avatar
    simpleaz is currently offline
    Send simpleaz:
    Here is one that appears to be like the Mariah stock one.
    Not sure of size but worth a look.
    Sea-Dog swim ladder
    Mine is underneath.
    for on top take a look here. I see yours is probably on top of swim shelf.
    another ladder link
    1996 Mariah Shabah 200 5.7L
    Ladder? 42hut Original Mariah Talk 4 07-28-2010 09:48 PM
    Ladder advice dfwguy Original Mariah Talk 2 12-09-2009 04:25 PM
    Is this ladder original? 1999Mariah Original Mariah Talk 7 06-26-2009 06:21 AM
    Ladder chadh Original Mariah Talk 9 05-07-2009 07:52 AM
    Wanted: Bow Ladder AndyFL Mariah Parts For Sale & Wanted 2 05-04-2009 01:05 AM
    Total Members: 18,995
    Total Threads: 13,326
    There are 294 users
