proper winterization
Old 08-11-2010, 04:56 PM   #1
Reed Hatch's Avatar
Reed Hatch is currently offline
My Model: Z252 Shabah
My Engine: 7.4L brovo III
Send Reed Hatch:
Default proper winterization
Is there someplace on this sight that shows the correct way to winterize your boat ? In the owners manuel page 142 says to follow your engine manuel for the proper way ( I don't have an engine manuel). I know to gas stable the gas, fog the motor but I want to make sure all of the water is drained or get antifreeze it. The boat is a 1996 z252 with a 7.4L ( not a closed cooling system) Thanks for the Help. Reed
  • Old 08-11-2010, 05:28 PM   #2
    Dagheyka's Avatar
    Dagheyka is currently offline
    My Model: Barachetta
    My Engine: 4.3L Mercruiser
    Send Dagheyka:
    Default Re: proper winterization
    Reed,
    The link below is a demonstration video for winterizing a Mercruiser Motor and outdrive that I found useful. Hope this helps.
    Technique - Winterize your boat
    Thank you Dagheyka for this useful post!
    josh3204 (10-15-2010)
    Winterization Z210Shabah Original Mariah Talk 25 10-03-2009 05:44 PM
    Proper Prop Specs? steve Prop Talk 16 04-29-2009 07:50 AM
    Advice for proper propeller for 2000 218 Shabah 5.0 merc I/O 250 H.P. rhtzi099 Original Mariah Talk 0 04-28-2009 12:18 AM
    Winterization Cost jasfiveo Original Mariah Talk 12 10-19-2008 03:08 PM
    There are 250 users
