1998 Mariah Jubile 214 Boat Weight
Old 08-10-2010, 10:17 PM   #1
dellis4 is currently offline
My Model: 214 jubilee
Send dellis4:
Default 1998 Mariah Jubile 214 Boat Weight
Does anyone know the boat weight of the 98 Jubilee 214? I need to tow the boat approx 200 miles and trying to determine what vehicle to use. I have a Volvo XC90, but not sure if the vehicle is equipped to pull the boat that distance.
Thanks for the help!
Dan
  • Old 08-11-2010, 02:08 AM   #2
    Shabah 198SE's Avatar
    Shabah 198SE is currently offline
    My Model: Shabah 198SE
    My Engine: 5.7L Alpha
    Send Shabah 198SE:
    Default Re: 1998 Mariah Jubile 214 Boat Weight
    The 1998 Mariah brochure states a weight for the 214 at 3,500 lbs. I would assume that this weight would be with the base 4.3 litre V6. The V8 would be a couple hundred pounds heavier. Remember to consider the weight of 72 gallons of fuel and gear.
    Shabah 198SE
    Old 08-11-2010, 11:26 AM   #3
    plus don't forget to factor in the weight of the trailer. I'd assume probably 1100-1200lbs if it's a steel trailer (like OEM Chariot or Prestige). You'll be very close to the maximum towing capacity of the XC90...
    Old 08-11-2010, 08:42 PM   #4
    Send dellis4:
    Thanks for the help! I do have the 5.7L V8. I figured the Volvo was too light. I've got a heavy duty Full Size PU that I'm going to pull it with. Appreciate the quick response.
    Dan
    Weight of 1996 Mariah Shabah 20' shabah96 Original Mariah Talk 2 07-28-2010 02:30 AM
    help-mariah davanti 275 weight?? roar82 Original Mariah Talk 2 11-10-2009 10:34 PM
    total weight of boat and trailer can anyone answer? lance Original Mariah Talk 3 02-05-2009 09:31 PM
    need info on boat weight jsk9675 Original Mariah Talk 4 07-01-2008 04:29 PM
    There are 253 users
