big block engine pull
Old 07-12-2010, 06:12 PM   #1
z272 barchetta's Avatar
z272 barchetta is currently offline
My Model: 1995 Mariah Z272 Barchetta, 502 EFI Mercruiser, Bravo I
Send z272 barchetta:
Default big block engine pull
I was wondering if anyone can point me in the right direction on 2 topics. First of all, I am in the process of replacing my 2nd flywheel ring gear. The first one was due allegedly to water in the #7 cylinder creating back pressure and not letting the flywheel turn. The flywheel was replaced prior to the water problem being taken care of. (basically replacing or refurbishing the entire engine from the block up) Now the 2nd flywheel has been stripped by the starter. My mechanic surmises the flywheel was weakened by the hard starting before the water problem was corrected.(this part is true, it was grinding occasionally before starting).
My 2 questions are this:
1) does my mechanics deduction seem reasonable and/or what else could make me burn through 2 flywheel gear teeth in 2 years.
2) I am not overly mechanically enclined but I want to try to save some $$ on the engine pull it requires to replace the flywheel. Is there a step by step website or manual out there to guide me through it?
Thanks for your feed back. Oh, I have a 1995 Mariah Barchetta Z272 with a 502 Merc engine. Bravo 1 XR outdrive. It was a saltwater boat and now is used on an reservoir in Ohio. Obviously, the salt water created the water problem in the cylinder in the first place. Thanks again.
  • Old 07-13-2010, 01:24 AM   #2
    willrev is currently offline
    My Engine: 7.4L Bravo
    Send willrev:
    Default Re: big block engine pull
    The reason we bought our Mariah was I was having the same trouble on a Sea Ray. Engine is being pulled right now for new ring gear. My problem was the starter was replaced twice. It used to make a ringing sound when starting that let you know the starter was tearing up the ring gear teeth. Went through two starters in four years. Either the starter was not aligned right or the salt water got to the ring gear down at the beach. But my guy is pulling the engine and replacing it for $300. Another mechanic quoted $600. Replace the oil pan while out and the plugs, but other than that, they should be good to go.
    Old 05-09-2011, 05:09 PM   #3
    corko is currently offline
    My Model: talari
    My Engine: 430
    Send corko:
    Did you find your step by step manual for pulling your motor??? If so, where can I find one for my 1996 Talari?
    draining water from block m&mmariah Boating 101 2 06-18-2010 03:00 PM
    Cylinder block warrenpark65 Volvo Penta 0 05-28-2010 08:27 AM
    1996 Shabah Where is Fuse Block? jsnelson Original Mariah Talk 3 07-14-2009 05:16 PM
    Engine Block Oil Stick Heater Douglas Alderman Boating 101 4 02-18-2009 05:17 PM
    Need to pull the sending unit MariahShabah3.0 Original Mariah Talk 5 02-21-2008 03:01 AM
    There are 362 users
