Weight of '95 180 Talari
Old 07-13-2010, 12:45 AM   #11
danheather's Avatar
danheather is currently offline
My Model: 182 shabah
My Engine: 4.3 mercery
Send danheather:
Default Re: Weight of '95 180 Talari
Thankfully I have a f-250 to pull my 98 182 shabah. I know my towing capacity is way over 3500 pounds, so i dont worry about getting there. But it would scare the hell out of me to put my boat in the water (and especially pulling it out of the water) with a crown vic or windstar. But i have saw worse around here though
  • Old 07-13-2010, 01:14 AM   #12
    95gts's Avatar
    95gts is currently offline
    My Model: Shabah 182
    My Engine: 3.0L
    Gallery Images: 4
    Send 95gts:
    Why would it scare the hell out of you? The vic weighs as much as my old '97 F150 shortbed (4200lbs), has more weight over the rear tires, v8, 4r70w tranny (same as the F150), full frame, etc.
    Old 07-13-2010, 02:05 AM   #13
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    The bigger problem with hauling a trailer + boat up the ramp with a two-wheel-drive vehicle is traction. I always put the TrailBlazer in at least 4WD HI. Those ramps can be darn slippery--at least the ones around here sure can be.
    Jim
    Old 07-13-2010, 02:25 AM   #14
    95gts's Avatar
    My Engine: 3.0L
    Gallery Images: 4
    Send 95gts:
    I've never had a problem pulling up a ramp with a rwd vehicle, but then again I am not boating in any saltwater, maybe that makes the ramps more slick.?. I'm also not pulling a very big boat.
    Old 07-14-2010, 12:41 AM   #15
    danheather's Avatar
    Send danheather:
    Im not sure what the boat ramps look like that you have been using, but the ones here are a little steep at most parks. I have seen 2wd f-150s having problems pulling 18 to 20 foot boats out of the water
    Old 07-14-2010, 01:43 AM   #16
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    We have aCorps of Engineers ramps at our local lake and it is absolutely no problem, no slips at all. I also launch at municipal ramps into the Mississippi river with no problem.
    I would NOT use my Windstar to launch at my river camp at one of my neighbor's private ramps. They are much steeper. I use my F150 4 wheel drive for them and it's still a little scary.
    Everybody's boating situation is different.
    Old 07-14-2010, 03:39 PM   #17
    SEMIJim's Avatar
    Send SEMIJim:
    Up here in Michigan the problem isn't so much steep ramps, as ramps made slick by seaweed. Depending upon what the season's been like, time of the year, direction of the wind, or any number of other variables, some of the ramps can be pretty bad. Last season when we hauled out of Lake St. Clair in late summer/early fall, the ramp was so slick we slightly lost traction with the TrailBlazer in 4WD Lo! Heck in 4WD Lo that truck can normally nearly climb vertical walls!
    Jim
    Weight bisket Chit Chat/Off-Topic 8 08-06-2011 08:33 PM
    Engine Oil Weight Douglas Alderman General Maintenance 11 09-02-2010 12:04 AM
    93 Talari weight Snowaterdude Original Mariah Talk 8 02-20-2010 12:12 AM
    what is the weight eric w Original Mariah Talk 3 01-04-2010 08:15 AM
    1996 Z235 Talari weight rssniff Original Mariah Talk 3 03-18-2009 12:02 AM
    There are 365 users
