Question on Smart Tabs versus Bennett Trim Tabs
Old 05-07-2010, 05:25 PM   #1
Rob 8043 is currently offline
Send Rob 8043:
Default Question on Smart Tabs versus Bennett Trim Tabs
I have a 1997 202 Shabah, that has a porpoising problem. I have debated installing bennett trim tabs versus Smart Tabs and I can't decide. Based on price and ease of installation I would prefer to use the Smart Tabs, but I don't want to invest the $200 if I am ultimately going to have to switch to the Bennett Tabs to solve my problem.
If anyone has had a porpoising problem that has been solved by installing tabs I would appreciate your input, and I am also curious if anyone has actually installed the Smart Tabls on a 202 Shabah.
Thank you in advance for your help.
Rob
  • Old 05-07-2010, 06:40 PM   #2
    Rdrdon's Avatar
    Rdrdon is currently offline
    My Model: Shabah 200 Limited Edition
    My Engine: 5.7L, Alpha One
    Send Rdrdon:
    Default Re: Question on Smart Tabs versus Bennett Trim Tabs
    I put the Smart Tabs on my 96 200 Shabah LTD, it solved my proposing & greatly improved my coming up on plane w/o the bow rise. Best thing I've done to it yet!
    Old 05-07-2010, 06:56 PM   #3
    Send Rob 8043:
    thanks, did you encounter any problems or issues regarding the placement of the tabs? At first glance, it looks like the tabs might interfere with attaching the tie down straps from the rear of the hull to the trailer?
    Old 05-07-2010, 07:21 PM   #4
    Rdrdon's Avatar
    Send Rdrdon:
    Yes, I did. Mine are mounted just about as tight as you can get them and I may have problems down the road because of how I installed them, almost as far outboard as you can get, I'll post a photo later to show it.
    Old 05-09-2010, 02:22 PM   #5
    rusty's Avatar
    rusty is currently offline
    My Model: 1998 shabah Z210 5.7L b-III
    Send rusty:
    I too am interested in trim tabs on my Z210.Would'nt the Bennetts interfere the same as the smart tabs?
    Old 05-10-2010, 02:32 AM   #6
    Rdrdon's Avatar
    Send Rdrdon:
    Here's a photo from my phone:
    * the orange strap isn't contacting the tab. The problem on mine is the vertical clearance, if something (a wave?) forces the tab up very far beyond horizontal, it will snap off the plastic clevis or mount. If I moved them far enough inboard to clear they wouldn't be very effective, or had I used the ST model they require less vertical clearance because the mount is adjustable.
    Old 05-12-2010, 11:06 PM   #7
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    Probably not because the Bennetts store in the" up" position unlike Smart-Tabs that stay down unless pressure is applied.
    I put Bennetts on 2yr ago, they work well but take some time to get used to. My wife still has trouble with them. Smart-Tabs would set them self. But if you need to control side to side roll Bennetts are best. IMO
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 05-14-2010, 01:48 AM   #8
    wplaine's Avatar
    wplaine is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Bravo III
    Gallery Images: 15
    Send wplaine:
    My smart tabs stopped the porposing, up'ed top speed by about 3 mph and on a plane with a full tank of gas and thrre people to aobut 4 seconds. WAY pleased with them and I havent even tried any of the other adjustment holes. they were only about 110 bucks.
    Old 05-14-2010, 01:50 AM   #9
    wplaine's Avatar
    Gallery Images: 15
    Send wplaine:
    Forgot to add I have the 215 Talari (21' cuddy w/5.7 L merc with b3 drive,lots of weight aft!
    Old 05-14-2010, 07:47 PM   #10
    karmann is currently offline
    Send karmann:
    Hello
    I put the smart tabs on my 95 barchetta 272 last year. I really didn't have a plane problem before, however it greatly improved preformance. I can go a lot slower and stay on plane.
    hope this helps.
    Smart Tabs indykoch Original Mariah Talk 327 04-05-2022 12:09 AM
    Smart Tabs Y-Knot Sea Fox - Mariah Talk 8 02-26-2010 06:37 PM
    Bennett M120 Sport Tabs Snowaterdude Original Mariah Talk 7 10-11-2009 05:19 PM
    Total Threads: 13,324
    There are 469 users
