Question on Smart Tabs versus Bennett Trim Tabs
Old 05-25-2010, 09:44 PM   #11
Rob 8043 is currently offline
Send Rob 8043:
Default Re: Question on Smart Tabs versus Bennett Trim Tabs
Originally Posted by Rdrdon View Post
Here's a photo from my phone:
* the orange strap isn't contacting the tab. The problem on mine is the vertical clearance, if something (a wave?) forces the tab up very far beyond horizontal, it will snap off the plastic clevis or mount. If I moved them far enough inboard to clear they wouldn't be very effective, or had I used the ST model they require less vertical clearance because the mount is adjustable.
What about the ladder, did the tabs interfere with it?
  • Old 05-27-2010, 06:45 PM   #12
    Rdrdon's Avatar
    Rdrdon is currently offline
    My Model: Shabah 200 Limited Edition
    My Engine: 5.7L, Alpha One
    Send Rdrdon:
    The ladder almost touches the cylinder, but not quite.
    Old 05-27-2010, 08:30 PM   #13
    melvin.franklin is currently offline
    My Model: Shabah202
    My Engine: 5.7 BravoIII
    Send melvin.franklin:
    Have you had a problem with the plastic snapping off? I am considering putting these on my Shabah202 to hopefully smooth out the ride on rough days. Also, is there a ladder clearance issue?
    Old 05-27-2010, 08:51 PM   #14
    Rdrdon's Avatar
    Send Rdrdon:
    I'll try to get a photo this afternoon, it was close on the ladder, but they made it. I haven't snapped the clevis pins yet, but if I had it to do over I'd go with the ST model that only require 8" of vertical clearance to avoid the issue altogether. Again, mine are mounted as far outboard as I felt possible, to get the best results from them. I put it on & raised it by hand, they will compress slightly past horizontal, any more & something will give.
    Old 05-28-2010, 12:10 AM   #15
    Rdrdon's Avatar
    Send Rdrdon:
    let's see if this works
    Old 05-28-2010, 12:12 AM   #16
    Rdrdon's Avatar
    Send Rdrdon:
    maybe?
    Old 05-28-2010, 01:12 AM   #17
    I've had them on my 180 for 3 summers now without any problems whatsoever.
    Smart Tabs indykoch Original Mariah Talk 327 04-05-2022 12:09 AM
    Smart Tabs Y-Knot Sea Fox - Mariah Talk 8 02-26-2010 06:37 PM
    Bennett M120 Sport Tabs Snowaterdude Original Mariah Talk 7 10-11-2009 05:19 PM
    There are 440 users
