Batt. switch
Old 04-16-2010, 03:26 AM   #1
bisket is currently offline
My Model: Shabah 218
My Engine: 5.7L Alfa 1
Send bisket:
Exclamation Batt. switch
Hello friends and neighbors,
I've got a 2001 Mariah 218 and and I started to have a problem with my starter batt. going dead. I looked down around the batt. and the batt. switch and found a wire cut. It's a small one with a round fuse but I cant read what amp it is. The one end is connected to the #1 selection on the switch. I used a jumper wire from the broken wire to the positive terminal on the #1 starter batt. and it work, what I mean by working is that it started with #1 batt. which it would start unless I used the both or #2 switch. II would then switch it back to #1 to charge the batt. What I really nead is a electrical diagram that shows how the batteries and battery switch is wired.. I forgot to tell you that that even though the jumper wire worked the wire got really hot so I dont think the jumper was in the right place even though it worked. I hope this all makes sense, if not ask me if there something I might be leaving out or did
Thanks to all. You have always helped!!!!
Ray Myers
    Kill Switch karmann Original Mariah Talk 5 09-11-2009 12:54 PM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    Light Switch karmann Original Mariah Talk 2 07-07-2009 06:41 AM
    Kill Switch grommett Original Mariah Talk 4 05-18-2009 06:47 PM
    There are 233 users
