1998 Z202 shabah limited edition dilemma
Old 03-02-2010, 07:24 PM   #1
stirn36 is currently offline
Send stirn36:
Default 1998 Z202 shabah limited edition dilemma
I am looking at 1998 Z202 shabah limited edtion solid red on craigslist.com. The boat has only 78 hours on it and loaded. I went to look at the boat and the thing looks like it just walked off the showroom floor. The dealership is asking $16995 for it but said he would take $15500. Does that seem like a good deal or am i still getting the shaft? help me out
  • Old 03-02-2010, 08:34 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: 1998 Z202 shabah limited edition dilemma
    Sounds like a beauty!! Also sounds like the dealer is awfully proud of it! That's pretty high, even with the low hours and condition. Look at NADA, but remember it's only a guide. The value is based on what the consumer would pay. So, being the consumer, is it worth it? I think it should be around $11k or $12k. It's 12 years old. Make sure you have it inspected if you decide to do it.
    One thing to remember, low hours can be a bad thing - hoses, belts, gaskets, etc. need to be used or they'll "dry rot". If it sat for a number of years unused, they could need replacing. Unless you want to play Russian Roulette and have something blow in the middle of the lake. Could be a bargaining tool, though.
    What engine does it have? Trailer included?
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 03-02-2010, 08:43 PM   #3
    Send stirn36:
    it has the 5.7 250hp mercruiser, custom tandem axle trailer and a spare tire
    Old 03-03-2010, 12:46 PM   #4
    MAJIC is currently offline
    My Model: 1997 Z252 Shabah
    Gallery Images: 9
    Send MAJIC:
    I agree with indykoch. Even in that good a shape I'm leery of the low hours. If it has been stored - was it stored properly - water drained and replaced with coolant? Cylinders "misted" with oil? Gas stabilized? Then all the other items that Indykoch mentioned.
    If the dealer can not present any maintenance records - then plan on doing a lot to get the boat ready: oil (lower unit and engine) changes, tune-up, hydraulic fluid check-up, ALL fuel filters. You may have to empty the gas tank.
    How's the trailer? Again with that age- what condition are the bearings? Are the tires showing dry rot? Have they been sitting in one spot and flattened? Wiring all work?
    The price is a bit high, even with the trailer. So my opinion - it should come out of their shop current on ALL maintenance, with a signed off checklist that they'll stand by for at least 90 days.
    I speak from experience in buying a boat (not a Mariah) that had been sitting for a couple of years!
    I belong to BoatUS and they have a very inexpensive add-on to add boat tows should you need it. They even have a trailer add-on too!
    Good luck!
    MAJIC - Z252
    Old 03-06-2010, 02:49 PM   #5
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    It looks to be in good shape. It's a true Limited as well - buckskin interior. Your local market will have a lot to do with price, but 15k for such a specimen around here wouldn't be too outrageous. As long as it's been serviced/stored correctly she should be quite a catch.
    My Mariah
    Mariah SX 22 Limited Edition Roberto Introductions 5 11-21-2011 03:42 PM
    Questions about 1998 Z202 Shabah possible z202 Shabah Owne Introductions 2 07-12-2009 02:53 PM
    1996 Shabah Z212 Limited Edition Blue Hull sydsam05 Mariah Boats For Sale & Wanted 0 06-15-2009 12:51 AM
    There are 338 users
