vinyl just startign to crack
Old 02-09-2010, 08:24 PM   #1
Jbetschart is currently offline
My Model: shabah 212z
My Engine: 350 mercruiser
Send Jbetschart:
Default vinyl just startign to crack
Is there a product out there that will help restore the softness to the vinyl so I can slow the cracking process down.
What about a product that I can put on the crack its self to keep it from spreading.
Don't really want to replace the sundeck just yet?
  • Old 02-09-2010, 08:44 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: vinyl just startign to crack
    Sorry to say it, but good luck. I tried a vinyl patch kit that helped slow down one area, but then a whole bunch more started and it was a losing battle. I religiously use Formula 303 protectant, but it was just too late. Not a whole lot you can do once it starts.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 02-09-2010, 09:28 PM   #3
    dlowings's Avatar
    dlowings is currently offline
    My Model: Z225
    Gallery Images: 8
    Send dlowings:
    I'm going to give this a try once I get my income tax return.. I'll post back as soon as I have it done..
    Fibrenew International - The Experts in Leather, Plastic and Vinyl Restoration - USA Franchises
    I have an area on my sundeck as well so I really want it to work out.. If I can buy two more years I can pay to replace it all.
    Old 02-10-2010, 04:10 PM   #4
    MAJIC is currently offline
    My Model: 1997 Z252 Shabah
    Gallery Images: 9
    Send MAJIC:
    There is vinyl tape you can use (similar to duct tape). It's not pretty, but it works for awhile. It doesn't hold up well to weather, water, etc.
    So if you're not overly concerned about looks (you have to match it as close as possible) and it's a reasonably small area, it might stop the rip from expanding.
    Keep the cushions conditioned. I use3 M PRODUCTS Vinyl Cleaner/Conditioner/Protector. Cleans well, keeps the vinyl soft and water beads up very well on it. I put it on extra heavy on the seams as that's where I'm seeing my first indications of pull and stress.
    MAJIC - Z252
    Old 02-11-2010, 10:09 PM   #5
    I had two small tears in my sunpad headrests, and I applied a drop of superglue to each of them. Granted it's stiff and quite a bit more rigid than the rest of the vinyl around it, but it hasn't gotten any larger in the past 4 years since I did that. I wouldn't recommend it for large areas, or for anything larger than say a dime, but as a temporary fix, it's worked for me.
    Old 02-13-2010, 01:00 AM   #6
    mariah bob is currently offline
    My Model: 1996 200 Shaba Limited Edition 5.7 Alpha One
    Send mariah bob:
    DO NOT use armorall, i found out the hard way!
    Old 02-15-2010, 04:40 PM   #7
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Armor All accelerated cracking, or what?
    Old 02-15-2010, 07:17 PM   #8
    IowaWing is currently offline
    My Model: 190 Talari
    My Engine: 4.3 L Alpha 1 Gen2
    Send IowaWing:
    I too am wondering "Why do you say 'DO NOT use Armorall' ?"
    IowaWing
    Steve
    Old 02-15-2010, 08:01 PM   #9
    Armor All is a silicone based spray.
    #1. Add water, and you'll have one of the most slippery surfaces around. There's many horror stories of people who have slipped and injured themselves and their guests on board.
    #2. The silicone over time will dry out the vinyl, and yes, cause cracking.
    Use a marine protectant, it's specially made to condition the vinyl, protect from UV's, and be much less slippery when it comes in contact with water. Sure, it may cost a bit more, but in the long run, it's worth it.
    Old 02-15-2010, 08:25 PM   #10
    Send IowaWing:
    I knew there had to be a good reason for not using it on marine vinyl. Thanks for the rest of the story.
    Any particular marine protectant you would recommend?
    IowaWing
    Steve
    Leather / vinyl Colin T General Maintenance 3 09-05-2008 10:23 PM
    Shabah Vinyl mspry Original Mariah Talk 2 08-21-2008 12:59 PM
    Vinyl Cleaning ShabahZ280 General Maintenance 5 12-05-2007 11:59 AM
    There are 364 users
