Vinyl Cleaning
General Maintenance
Old 12-03-2007, 12:51 AM   #1
Default Vinyl Cleaning
Actually SLP, I was referring to Vinyl Decal work, (revised my post).
But, have you tried Acetone? I know it sounds nuts, but one of Mariah's big selling points on their upholstery was the use of PreFixx, a vinyl coating that was applied on all vinyl surfaces as a stain deterrent. In the old Mariah brochures, it shows all sorts of stains, mustard, sharpie markers, paint, etc. It claims "All you need to do to remove stains is just wipe it clean with a towel and a slight bit of acetone."
  • Old 12-03-2007, 01:24 AM   #2
    S.L.P. is currently offline
    My Model: 2000 Z260 MCC 7.4L MPI BravoIII
    Send S.L.P.:
    Default PreFixx
    Found the PreFixx brochure in the Mariah binder. Sure enough, acetone/water can be used on the vinyl. Unbelievable. I will try the other cleaners and solvents listed before acetone. Also listed is :rubbing alcohol,min spirits, kerosene, naptha, and turpentine. But "dont get any sunscreen oils on the vinyl as it may stain".
    Thanks to this brochure, I am now prepared to remove stains such as:
    Revlon Lipstick, KIWI shoe polish, Canon Toner, Vitalis hair oil, baby oil, and French's mustard!
    Geez! Wish I had read this prior to last summers party with the girls from the beauty salon.
    steve
    2000 Z260 7.4L Bravo III
    Old 12-03-2007, 12:34 PM   #3
    boatman's Avatar
    boatman is currently offline
    My Model: 1996 200 Shabah 5.7L Apha I
    Send boatman:
    Good One! Let us know how the Acetone works. I still have some stains from the cheap cover I bought last year that bled blue dye onto my seats.
    Mark
    '96 Shabah 200, 5.7L
    Old 12-03-2007, 11:03 PM   #4
    I used it on one small section of my sunpad at the end of the season, and it's amazing how clean that one little area was.
    Old 12-05-2007, 03:49 AM   #5
    97 Z222's Avatar
    97 Z222 is currently offline
    My Model: 97 Z222 Shabah,7.4L carb, Bravo I 21p stainless 3 blade prop
    Send 97 Z222:
    Acetone?! I'm in the floor covering business, and we use acetone to chemically melt vinyl togeather. I would think you would have to dilute it alot, not to damage the vinyl. It's a great solvent, but I think I would use all the other cleaning methods first.
    Old 12-05-2007, 11:59 AM   #6
    That's what I thought too at first, but they even show the vinyl being cleaned with acetone in one of the videos I have. It's also listed in the brochures too. Of course, they recommend it if other cleaners & solvents won't remove it first. I would slightly dilute it just to be on the safe side.
    Vinyl Repair pics! bpfirrman General Maintenance 15 08-01-2008 02:51 AM
    There are 269 users
