dumb question?
Old 01-20-2010, 03:39 AM   #1
theblochs is currently offline
Gallery Images: 2
Send theblochs:
Question dumb question?
Since finding an original bucket seat/pedestal is such a long shot, I'm wondering if I can modify the replacement pedestal-it's way to high, my knees barely clear the steering wheel at full tilt. My question, though is can I remove the pedestal bolts without the nuts falling into the hull? I'm assuming Mariah used a backing plate and machine screw threads with nuts, rather than just sheet metal type screws to hold the pedestal to the deck. If so, I won't be able to replace the bolts unless the nuts underneath are captive some how. Has anyone removed/replaced a pedestal? Any hints would be much appreciated. Thanks in advance!
Brian
theblochs 180 Talari
  • Old 01-21-2010, 04:51 PM   #2
    Default Re: dumb question?
    You had most of it right Mariah did use a 12" x 12" aluminum backing plate that was predrilled/threaded to accept the pedestal mounting bolts which i believe were 1/4" x 2 3/4"L.
    I assume that whoever changed the pedestal simply replaced an existing one & used the same bolt holes....
    I bought the following fixed height pedestal thru Cascade Depot (Swivl Eze Bell Pedestal Fixed Height) which worked with my Mariah bucket & spider assembly.
    SKU: 238910
    This is a 2-3/8" Bell Pedestal Fixed Height. Pedestal tubes are hard anodized aluminum. Base is bead-blasted and clear coated.
    Used in Avalon & Tahoe Boats
    Pedestal measurements: From the deck to the top of the tube is 7-1/2". From the deck to the top the swivel is 10"
    Base: 9"
    Base Finish: Satin
    Designed for "Saltwater Enviroment"
    Old 01-22-2010, 04:14 AM   #3
    Gallery Images: 2
    Send theblochs:
    Smile Re: dumb question?
    Thanks Mikey! Now, if I could only find an original seat....
    See if You Can Top These 2 Dumb Rookie Mistakes Z280Bob Boating 101 17 06-07-2010 07:17 PM
    There are 277 users
