white plastic bottle on the engine
Old 11-30-2009, 09:29 AM   #1
embasun's Avatar
embasun is currently offline
My Model: z250
Send embasun:
Default white plastic bottle on the engine
Hi all i have a small white plastic bottle on the right hand side of the engine at the top and it is empty what goes in it can anyone help
  • Old 11-30-2009, 01:32 PM   #2
    Default Re: white plastic bottle on the engine
    It's the gear oil reservoir, and it shouldn't be empty. That could be what's setting off your alarm. But I'd still take it to a mechanic to find out if that's the problem.
    Old 11-30-2009, 01:49 PM   #3
    embasun's Avatar
    My Model: z250
    Send embasun:
    Thank you do you know what oil it is ??
    is it the same as outboard gear oilAPI GL-4
    Thank
    Old 11-30-2009, 03:36 PM   #4
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    Hi Embusun, The item below is straight out of the Mercruiser Engine Owners Manual.
    If you dont have one, become a contributing member and all sorts of manuals etc are available to you, absolutely essential reading, especially for beginners.
    Hope this helps mate.
    CHECKING DRIVE UNIT OIL
    NOTE: Oil level will fluctuate during operation. Oil level should be checked with cold engine before starting.
    1 Check gear lube monitor oil level. Keep oil level at or near FULL line. If any water is visible at the bottom of
    monitor or appears at the oil fill/drain plug and/or if oil appears discolored, contact your Authorized Mercury Mer-
    Cruiser Dealer immediately. Both conditions may indicate a water leak somewhere in the drive unit.
    IMPORTANT: If more than 2 fl. oz. (59ml) of Quicksilver High Performance Gear Lube is required to fill
    monitor, a seal may be leaking. Damage to drive unit may occur due to lack of lubrication. Contact your
    Authorized Mercury MerCruiser Dealer for service.
    Tony
    Perth, Western Australia
    Old 11-30-2009, 04:55 PM   #5
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Low reservoir doesn't necessarily mean a leak. Quite often whomever fills the drive may inadvertently left an air pocket in the drive itself, which will get filled up (from the reservoir) as the drive is operated. If the reservoir was low to begin with, it may just have drained whatever was left in there.
    It will definately cause your alarm to sound continuously if it's empty.
    I'd fill it up (with the correct lube) run it a bit and see if the level drops appreciably.
    My Mariah
    Old 11-30-2009, 06:47 PM   #6
    embasun's Avatar
    My Model: z250
    Send embasun:
    thank you very much for you help
    Black plastic trim piece around radio jasfiveo Original Mariah Talk 2 05-19-2009 05:13 PM
    white build up on outdrive PROPNUT General Maintenance 10 04-05-2009 09:01 PM
    White light on a Talari 180 Tilted Original Mariah Talk 12 09-20-2008 12:49 PM
    replace windshield with plastic windscreen? Ultraboy Original Mariah Talk 0 04-29-2008 04:39 AM
    Rafting (not white water) 180diablo Boating 101 6 08-14-2007 06:20 PM
    There are 340 users
