hour meeter not working
Old 11-03-2009, 03:09 PM   #1
Jbetschart is currently offline
My Model: shabah 212z
My Engine: 350 mercruiser
Send Jbetschart:
Default hour meeter not working
I have an hour meeter that is not working. Is it usually as easy as installing a new one or do you need to check somewhere else.
It appears to be frozen?
  • Old 11-06-2009, 07:57 AM   #2
    Default Re: hour meeter not working
    Hi Jbetschart,
    The Hour Meter is very simple, there are only two wires (ground and positive) and it runs when ever it has power. Replacing the meter is a relatively easy affair if you can get behind the dash, it should be held in place by a "U' shaped bracket and a couple of nuts. If you can, see if the ground and power to the Meter are good before trying to replace it.
    If your Hour meter is made by Faria, they offer a Marine Limited Lifetime Warranty and will repair it for a nominal fee, click here for their information.
    Hour Meter Suggestions? SEMIJim Mercury MerCruiser 4 06-27-2013 09:32 PM
    Hour Log not working john elbro Mercury MerCruiser 2 07-27-2009 02:36 PM
    Hour meter on 198 Shabah Hyperryd Original Mariah Talk 4 04-03-2009 01:12 PM
    Hour Meter ROBERT Original Mariah Talk 5 05-31-2008 04:23 PM
    Inaccurate hour meter. z275st Original Mariah Talk 6 02-23-2008 02:20 AM
    There are 245 users
