Hour Meter
Old 05-22-2008, 09:08 PM   #1
ROBERT is currently offline
My Model: 2001 Z212 78 HRS. LIMITED PHOENIX YELLOW WITH INDY GRAPHICS
Gallery Images: 13
Send ROBERT:
Default Hour Meter
O.m.g. Is This As Hard To Get Out As I Am Making It Out To Be?or Can Some One Let Me In On The Way To Get This Out On My 2001 Z212.thanks
  • Old 05-22-2008, 09:50 PM   #2
    What are you trying to do, remove it from the dash?
    Old 05-23-2008, 12:46 AM   #3
    Gallery Images: 13
    Send ROBERT:
    Angry
    Yes I Need To Put A New One In And The Dash Has A Lot Of Things In It.i Cant Seam To Get My Arm Up Under It To Get To The Mount For The Guage
    Old 05-23-2008, 01:24 PM   #4
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    I have the same model, but I can't say that I've tried reaching the hour meter. I've tried all the others though!!!! If I remember correctly, there are 2 nuts (I think 3/8") on the back of each gauge. Try contorting your hand back there with a socket if possible. Remove the nuts and you should be able to pull the guage out. Once it's out, you can see exactly how it's held in and makes things easier from that point.
    Are you going to use an original Mariah gauge from Faria? If not, maybe you could have them fix it under their lifetime warranty? That way it would match the existing gauges...
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 05-23-2008, 02:05 PM   #5
    indykoch is correct. however I'll tell you that it's a 2 piece mounting system. The gauge is seperate, and there's a square mount piece that holds it flush in the dash. (It's the only square one in the dash). It's secured by 2 bolts, which I believe are 3/8". I've attached 2 pics that should help you visualize it. The first pic is looking down from behind the dash, and the second one, you can see the hour meter in the lower right corner. They're terrible pics from when I repaired my dash, and used these pics for wiring reference. But they'll give you the idea.
    Hope this helps!
    Old 05-31-2008, 04:23 PM   #6
    Gallery Images: 13
    Send ROBERT:
    thanks for the info i am so bussey and have not had the boat yet this year but i just put my bats. and plugs in last night and trying got out on the lake to day but the rain and weather is not in my favor.my boat has carpet on the floor it looks like the floor is finished fiberglass is that the case and can i tale up the carpet and make a snap in carpet.i am going to try to replace my hour meter tonight it is tght under the dash
    Inaccurate hour meter. z275st Original Mariah Talk 6 02-23-2008 02:20 AM
    depth meter harry van kesteren Original Mariah Talk 6 09-13-2007 10:14 AM
    There are 374 users
