Windsheild for 240 PC Talari Special Edition
Old 10-22-2009, 06:04 AM   #1
sweetdreams is currently offline
My Model: 1998 PC Talari 246 Limited Edition
My Engine: mercruiser V8 7.4L
Send sweetdreams:
Default Windsheild for 240 PC Talari Special Edition
I guess I shouldn't have ventured out in that Noreaster last weekend, but I did, and got a little slap happy on the surf, until a section of the port windshield panel shattered. The long, triangular shaped section that slopes down along the side of the boat needs replacement. Does anyone know from who or from where I can get windsheild replacement parts?
If I found an old boat that would be great, but so far the best I can do is have a glass company make a piece of laminated glass, similiar to a car windsheild, using the mirror image of the piece on the starboard side.
Has anyone else dealt with this, and have an easier solution? If so, let me know please!
Steve
  • Old 10-22-2009, 04:05 PM   #2
    AirNavy's Avatar
    AirNavy is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Alpha One
    Send AirNavy:
    Default Re: Windsheild for 240 PC Talari Special Edition
    Here's a thread with the contact info for the original manufacturer (Taylor Made) and other details you will need: Taylor Made Windows
    Mickey
    AEC (AW) U.S. Navy
    Old 10-22-2009, 04:42 PM   #3
    Send sweetdreams:
    Mickey,
    Thanks for the thread. It sounds somewhat encouraging, and I have all winter to do it, but I will keep the list posted.
    Steve
    Old 12-01-2009, 05:39 AM   #4
    Send sweetdreams:
    Well I finally resolved my windshield repair, and thought I would update the forum in the event any other members have the same problem. My boat is the 1998 246 PC Talari, and the windshield section running behind the vented window, on the port side, had shattered. Fortunately the shattered section was not the highly curved piece in front.
    The windshield was made by Taylor Made, but there are several different manufacturing locations, so wherever you call first make sure they direct you to the Taylor factory which made your glass. Mine was made in New York (518-773-0636) state.
    I went back and forth for several weeks, and in the end determined from pictures that my piece was out of stock, and although they had the engineering plans for the glass, to actually make the piece of glass I was told would require retooling a machine just for that piece, and would likely cost thousands of dollars. I got slightly different answers from different customer service agents, ranging from "I think I have identified your glass, and we may have it in stock", to "we haven't had that glass in years and we are not likely to produce it again.
    It's possible that they did have a piece of my glass lying around, but it didn't seem like they really knew, or even wanted to try hard to look for it. I eventually removed the broken section of the windshield myself, brought it to a good glass shop in town, and they reproduced the same color and material as the original, for $164.00. If you can remove the glass frame, that is going to be your best bet.
    Another important note, is that the number which taylor asks you for, printed on a sticker on the inside of the trim, only identifies the the curved front of the windshield. There is no part number for the tail piece which extends toward the stern, and that must be identified with pictures and measurements.
    I hope this helps someone.. and Good Luck!
    Old 12-01-2009, 08:21 AM   #5
    Hi sweetdreams, thank you for the informative update about the windshield glass. This has got to be one of the most difficult parts to replace and your experience and solution will definitely help our members! Great work
    WIndsheild randylog3 Introductions 5 01-29-2010 04:01 PM
    Something spécial to registred my boat Pixi Chit Chat/Off-Topic 0 09-06-2009 12:12 PM
    Windsheild Provo Original Mariah Talk 2 05-27-2009 02:34 AM
    A special thanks (A mariah Owners club member must read lance Original Mariah Talk 1 02-17-2009 08:04 PM
    There are 250 users
