Question about stern / pole light
Old 08-05-2009, 01:13 AM   #1
1999Mariah's Avatar
1999Mariah is currently offline
My Model: 1999 Shabah 182 Merc 3
Send 1999Mariah:
Default Question about stern / pole light
The light did not work when I bought the boat. I have since gotten the wiring diagram from MOC, and it says the "Pole Light" is the gray & blue wire. Well...when I look for the wires from the boat to connect to the light pole fixture, the boat has black / gray / blue + gray line wires. I can get an always on with the gray + black wire, but no other combination seems to work with the switch for nav lights...Can someone help me?
  • Old 08-12-2009, 06:39 AM   #2
    1999Mariah's Avatar
    Send 1999Mariah:
    Default Re: Question about stern / pole light
    Okay...well does anyone know if the stern light mount should be a 'hot' (always on) setup? where whenever I plug the light pole in it lights up.
    Old 08-12-2009, 09:44 AM   #3
    Hi 1999Mariah,
    No, the stern light should only be hot when the Nav lights or just the Anchor light is switched on. Any other time, it should be off.
    You will need to trace out the wires from the Lighting switch back to the Stern light. What you should have are two power wires running from the lighting switch back to the stern light and each pin contact and one ground connection to the pole itself. Is your Nav/Stern light switch a rotary or rocker style?
    Old 08-12-2009, 12:17 PM   #4
    1999Mariah's Avatar
    Send 1999Mariah:
    Thanks for the reply ww. My friend and I were up until 3 am trying to figure it out, he's more electrically knowledgeable than I but we were unable to figure it out...
    It's a rocker switch, it says NAV on the front toggle and Anchor on the rear toggle, and NAV illuminates the bow light and the gauge/button lights, Anchor does nothing. Is what you're saying is there should be 2 power wires + 1 ground to the pole mount? If so, I only see 2 wires coming from the pole mount, should we be grounding it elsewhere?
    Also, on the NAV button, there is a black (ground?) and a gray (assuming the pole one) that come out on the top left of the bottom of the switch if viewed from the top (aerial) and the gray one was disconnected when we were experimenting, having the black + the gray plugged in caused a 7.5 amp to blow...
    Old 08-15-2009, 09:03 PM   #5
    Hi 1999Mariah,
    Well I guess we'll just have to figure this out one wire at a time so, can you post a picture of the back of the Nav/Anchor switch or tell me how many tabs it has and what color wires are currently connected to the switch and to which tabs?
    Old 08-17-2009, 09:27 PM   #6
    1999Mariah's Avatar
    Send 1999Mariah:
    Thanks WW, I'm going to put this task off until the season is over though, I have a few things I have to tackle off season already, so I'll post back here when the time comes.
    power stern light rusty Original Mariah Talk 11 04-24-2022 03:08 AM
    rear light pole john elbro Sea Fox - Mariah Talk 3 07-30-2009 02:11 PM
    For Sale: Automatic Stern Light MariahMan Mariah Parts For Sale & Wanted 2 08-09-2007 12:21 PM
    There are 260 users
