Ran into some trouble
Old 05-25-2009, 07:22 PM   #11
aquaknot's Avatar
aquaknot is currently offline
My Model: z222 shabah
My Engine: 7.4l EFI-Bravo 1
Send aquaknot:
Default Re: Ran into some trouble
thanks Jim, great photo. The carpet that is under the walkthru to the bow on my boat needs to be repaced (it's glued under there-I have no idea why). Any thoughts would be appreciated.
Tod
1999 Mariah Z222, 7.4L MPI
2004 Lowe 16 ft aluminum, 25hp 4stroke
1995 pontoon 18 ft, 50hp mercruiser
198? aluminum 14ft, 6.6hp fisherman
  • Old 05-25-2009, 10:27 PM   #12
    s.a.charlie's Avatar
    s.a.charlie is currently offline
    My Model: 93 talari"z" 19 5.0 mercruser alpha 1gen2 54mph so far
    Send s.a.charlie:
    i read this post last week or so why is it listed as today !!!
    Old 05-26-2009, 01:32 PM   #13
    jimshabbah is currently offline
    Send jimshabbah:
    aquaknot - Unfortunately I really can't offer any good ideas. I decided not to do anything with the carpet under the walkway in the bow because i couldn't figure out how to remove it without separating the top shell from the bottom. For me, the carpet underneath was still fine and since you can't see it with everything put back together, I just left it alone. It looks like they must do the carpet install at the factory prior to attaching the top shell. It would certainly be easier for them.
    Just curious, how do you know it needs to be replaced?
    Old 05-26-2009, 04:24 PM   #14
    aquaknot's Avatar
    Send aquaknot:
    jimshabah-it needs some attention because when you walk on it, it feels soft or spongy so when I removed the metal moulding at the front of the walkway floor, put my fingers in between the two layers, the carpet feels punky and wet. I think the carpet has deteriated and needs to be replaced.
    Tod
    Old 05-26-2009, 06:05 PM   #15
    Send jimshabbah:
    If you do find a way to get to it, let me know. I wasn't real happy about having to leave the old carpet there when I did mine.
    If the floor is spongy, you might have to replace the floor board as well. If that is the case, I can't see how you could fix it without removing the top shell.
    I know on my Z222, both the anchor locker and the bow built-in cooler drain underneath that walkway. Maybe try and keep it dry for a week or so and then check it again. If it is still spongy, you might have found yourself a nice little winter project.
    Engine trouble grommett Original Mariah Talk 5 04-26-2009 09:09 PM
    Trim trouble shilo Sea Fox - Mariah Talk 5 02-20-2008 02:24 PM
    Having trouble with avatar shilo Introductions 3 01-27-2008 07:10 AM
    trim trouble aquaknot Original Mariah Talk 5 08-13-2007 12:17 PM
    There are 307 users
