leaking hydrolic fluid
Old 04-20-2009, 05:14 PM   #1
Kitto's Avatar
Kitto is currently offline
My Model: 2002 Diablo 200 5.0L Merc. Alpha 1
Gallery Images: 7
Send Kitto:
Default leaking hydrolic fluid
Got another question for anyone who can help. When I purchased my boat I had a small pool of hydrolic fluid in the back of the boat that had escaped the stearn drive motor. As a result the stearn did run smoothly. I couldn't tell where the oil leaked from so I added a bit more and ran the stearn a bit and have the leak again. Any ideas where this is coming from? As well, there isn't a dip stick or line to show what the proper amount of oil it would require. Any suggestions?? Thanks, if the weather holds I'm taking the maiden voyage tonight. Wish me luck.
Kitto
2002 Diablo 200 5.0L Alpha 1
  • Old 04-21-2009, 08:42 PM   #2
    anthonybradley is currently offline
    My Model: Z216 '97 Merc 5.7l Alpha one.
    Send anthonybradley:
    Default Re: leaking hydrolic fluid
    could be power steering fluid, trim pump fluid or gear oil for the leg, where did u top up / what level was low. Some drive legs are filled at the actual leg, some have the optional remote oil filler which has a white plastic bottle on the engine. The power steering fluid in normall y in a tank on the actual pump itself, the trim (leg up / down) pump has the tank under the pump. Important that all are kept up to the right level!
    Ants
    Draining tilt,trim,fluid reservoir Douglas Alderman Mercury MerCruiser 20 05-07-2010 05:22 PM
    Leaking Gear Oil 300sflyer Mercury MerCruiser 4 03-31-2008 02:00 AM
    Fluid question. KSP181 Mercury MerCruiser 3 08-01-2007 03:11 PM
    There are 429 users
