Leaking Gear Oil
Old 03-30-2008, 01:38 PM   #1
Send 300sflyer:
Default Leaking Gear Oil
A few weeks ago I changed the water pump and housing on my 94 Alpha 1 Gen 2 outdrive. I used an original OEM water pump kit, which included the impeller and the new housing. I had no idea when it was last done, so I figured it was time.
I followed the service manual I have to do this and all seemed to go fairly smoothly. The outdrive is stored verticaly in my shop, and about 3 weeks later, I notice oil running out through the water pickup holes.
Any ideas on where I may have gone wrong? It was not leaking before I did this.
Thanks in advance!
  • Old 03-30-2008, 02:56 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    There is an oil seal that goes in during re-assembly of the lower unit. Did that get installed or perhaps improperly seated or pinched?
    My Mariah
    Old 03-30-2008, 03:02 PM   #3
    Send 300sflyer:
    I assume you mean the the small seal that goes in between the upper and the lower? Yup its there... I made sure of that.
    Old 03-30-2008, 09:30 PM   #4
    Send 300sflyer:
    Found the problem...
    The base I replaced below the pump assembly, has an inner and outer o-ring to provide the seal. The outer ring is damaged. I guess I must have done it somehow when I installed it...
    Im sure a new one will fix the problem.
    Old 03-31-2008, 02:00 AM   #5
    It's easy enough to do for sure. Hopefully the new seal will solve your problem.
    i/o lower unit gear oil bryce6horse Mercury MerCruiser 1 04-25-2008 03:53 PM
    Found where all that gear oil went to! S.L.P. Mercury MerCruiser 0 11-20-2007 01:13 AM
    There are 432 users
